Walked into the garage yesterday morning and there was radiator fluid on the garage floor. It was leaking out from the water pump. Tightened it up, wiped it down and threw a tray under it and had to run out for the day and had friends coming around in the afternoon so couldn't look at it until today.
Drained the radiator out and took off the pump and checked the seal and checked there wasn't anything on the pump and the elbow and refitted and filled with some water to test it. Again it was leaking.
Looks like I'll put on some gasket glue and test it again otherwise it's a new seal and problem solved.
I won't get to the brake line this side of the trip to Vietnam.
MY11 Multivan 132kW 4Motion, Natural Grey, Fog lights, Multifunctional Steering Wheel.
