Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 47
Thread: 76 Blue 2 Door
    Mar 2011
    Wagga Wagga
    im jealous as it looks so neat
    2.0 mk4 golf (SOLD)
    mk1 76 4door ( long project)
    May 2010
    Lalor Park, Sydney
    These arrived today, eBay AUS bargain, two for the price of one
    MY11 Multivan 132kW 4Motion, Natural Grey, Fog lights, Multifunctional Steering Wheel.
    May 2010
    Lalor Park, Sydney
    Checked the meat on the brake lads and bled the brakes, adjusted the clutch and flushed the water pump and radiator again to ensure its super clean and condfirmed the water pump is working like a tropper.
    Took it up and down the street and she was driving so much better, then the misses gets in the drivers seat and runs up and down the street and is loving it until a big squirt of brake fluid shot up from the metal hose on the drivers floor and got her in the face. when knew she was ok I laughed my ass off.
    No wonder the floor was all wet and rusty there.
    Until I can replace the metal brake line is there a way to fix a small pin hole in the line with something, maybe some of that clear silicon filler?
    Oakleigh VIC
    Nope. You need to replace the line. The brake system operates at pressures up to 1000psi.
    They're easy to make, any decent brake place will sort you out.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    May 2010
    Lalor Park, Sydney
    WOW a 1000PSI! I had no idea. I'll replace the line. No sense in doing something half ass.
    Oakleigh VIC
    A brake place can make the entire line which runs from the master cylinder to just under the back seat or just make a repair section to replace the rusty bit.
    For some unknown reason, when a brake line rusts through it will always create a hole pointed directly at the car's occupants.
    7? MK1 Caddy
    12 Amarok
    May 2010
    Lalor Park, Sydney
    Walked into the garage yesterday morning and there was radiator fluid on the garage floor. It was leaking out from the water pump. Tightened it up, wiped it down and threw a tray under it and had to run out for the day and had friends coming around in the afternoon so couldn't look at it until today.
    Drained the radiator out and took off the pump and checked the seal and checked there wasn't anything on the pump and the elbow and refitted and filled with some water to test it. Again it was leaking.
    Looks like I'll put on some gasket glue and test it again otherwise it's a new seal and problem solved.
    I won't get to the brake line this side of the trip to Vietnam.
    Apr 2006
    Melbourne, Victoria
    Leaky quarter vents + brake lines + carpet = rusty floor + no brakes
    Internally running the brake lines was not VWs greatest idea
    Beige 79 Mk1 GLD White 76 Mk1 LS 3 door
    White 68 Alfa 1750 Berlina Champagne 91 Alfa 75
    Red 09 9N3 Polo TDI White 2010 Skoda Octavia Combi TDI
    Sep 2009
    Chillaxing in Tas
    Quote Originally Posted by hiho View Post
    1980 changed that, they changed it to under the car. ive had a look at both floor pans from a 78 and 80 and i see no way to run them under the car on a early model which sucks. Ive had to replace 2 broken lines, current car has a repair section done near the passenger seat.
    <space for rent>
    May 2010
    Lalor Park, Sydney
    Hmmmm that's a shame coz I was going to look at moving them underneath the car
