Page 11 of 12 FirstFirst ... 9101112 LastLast
Results 101 to 110 of 114
Thread: 5teve's mk1
  1. #101
    May 2012
    Tullamarine
    Tried to fill up the water system with water and noticed that the core of the radiator had small leaks
    Now looking for another replacement diesel radiator!
    If anyone has one thats in good condition and no leaks/bursts please notify me!
    MK1, 1976 golfLS, 4 door (SOLD! Will be missed)
    MK1, 1980 golfGLD, 4 door (1.8l, 8v, 5 speed)
  2. #102
    May 2012
    Tullamarine
    brought a new carter 5psi fuel pump from VPW today, ive located the external fuel pump on the rear of the car where the spare tyre compartment is. i ran new hoses from the petrol tank to the pump and from the pump to the fuel line feeding the weber. i also inserted multiple fuel filters on the line so it can reduce dirt that access the weber.
    heres some pictures!
    fuel pump
    fuel lines
    fuel feeding the weber
  3. #103
    Dec 2008
    Bentleigh, Melbourne
    Nice work Steve,
    didn't that engine have a mechanical fuel pump attached?
    the mech pump is the blob just to the left of the dizzy, has an inlet and outlet pipe.
  4. #104
    May 2012
    Tullamarine
    Quote Originally Posted by Stiggy_21 View Post
    Nice work Steve,
    Thanks! No unfortunately it didn't have a mechanical fuel pump. This motor is out of a later golf which had a electronic fuel pump.
    the blob your talking about is a fuel regulator if I'm not wrong?
  5. #105
    May 2012
    Tullamarine
    the other night i received a package from VW heritage which contained new steering rack boots, clutch cable, clutch bulkhead repair plate and new crystal clear headlights. also popped into auto1 and brought myself a color coded spray can to touch up the engine bay/clutch plate.
    sorry about the picture quality used my iphone!
  6. #106
    Jun 2007
    Eastern Suburbs Melbourne
    Firewall panel is a lifesaver. I was lucky and had them on my mk 1's before I bought them.
    (please mount the number plate in the centre )
    i like volkswagens
  7. #107
    May 2012
    Tullamarine
    I would of predicted the mk1 firewalls would of been tougher! By the sounds of your mk1s all having the plate it would of been a common problem!
    i was also testing the clutch an every time I put my foot down on the clutch it feels like it's not pulling when it is and when i release the clutch and quickly put my foot down it feels like im pushing down on air! That's how easy its pulling. there's basically a few seconds wait until i can put my foot down again. I've also adjusted the cable so there's no slack in the cable, clutch leaver is just below half way up. Does this sound right?
  8. #108
    May 2012
    Tullamarine
    Time for a little update:
    Havnt posted any progress on this mk1 for ages! so I've found some spare time this sunday that passed, so a mate and I tackled the wiring! Converting diesel to petrol!
    Here comes the challenge which consists of slicing and dicing!
    Okay for starters we mounted the battery tray in the boot and ran 00 BSN cable to the starter motor, connected alternator cable to starter motor and the sensor wire back to dash, we got the lights behind the dash to work and igntion cable to the starter motor, ran fuel pump wire to relay and back to the fuse box and also added a kill switch for the fuel pump, sensor wires connected to gearbox, ran wiers to the distributer, rain power to auto choke on the weber and re-wired all the cables that are running across front which contain front headlights, indercators, horn and wiper pump as all the cable/copper were brittle! We got sensor wires to run to the oil filter, sensor wires to run to the brake cylinder, thermo fan needs to also be wired up and it's basically ready to start!
    We also ripped out a fair bit of wires we didn't need! And now engine bay looks much cleaner!!
    Here's some pictures
  9. #109
    May 2012
    Tullamarine
    hey guys im in a prediciment at the moment! ive got the mk1 running and majority of the wiring done and also need to replace the heater fan but have encountered another issue which involves the gearbox! arghhhh nothing ever goes right!
    when i drove it around the block the gearbox seems to slips/jolt constantly! when i plant my foot down would anyone know what may be the problem? i know for in fact when i re-filled the gearbox with transmission fluid i pulled off the speedo cable which is the correct place to top up from...
    thanks
    steve
  10. #110
    Did you put autotransmission fluid in a manual gearbox?
