Originally Posted by
GRN_VAGN
ok ill make it clear
I picked a BLue Mk1 with this engine in it last saturday. i got in, turned key and it started first pop.
I drove it home which was an hour trip, ran awesome.
It diesel'd a bit when i shut it off at home, but i though it was because the car hadnt been run in a while.
I took that 1.8L out of the blue golf, took the 1.6L out of green one,
Dropped 1.8L in green golf and hooked up the electric pump and everything else the blue one used.
Turned key and nothing, just kept cranking over. eventually started and it idled and revved fine, but i didnt drive it. shut it off, bleed brakes after i got the GTi rotors on. rain came so went inside. 2 hours later i went out and nothing, just kept cranking over.
and when i turn key to crank, it cranks fine, put key back to "on" and its good. turn key all way off and the engine kicks over a tad. not a full turn, but a quick blip...
Ill get timing checked, and ill make sure pump and lines are good. Then go from there.
Sounds too far advanced as a car too far advanced can start easy then not play ball later on. Agree with other posts here, invest in a timing light, a dwell meter and a Haynes Manual or similar to get the specs
1991 Golf GTI Manual - Tornado Red (Little Red Wagen)
1998 Golf Cabriolet Manual - Black Magic Pearl (aka Rommel's Panzer) Deceased/written off
1993 Golf Cabriolet Manual - Alpine White (aka Hitler Youth Wagen) Deceased/written off
1976 Golf LS Manual - Bronco Brown (aka Roadrunner) Deceased/worn out
