clockwise retard, anticlockwise advance...
you can figure it out too... just look at hte leads on the dizzy, and which plug they go to. the firing order is 1342... that gives you the correct direction of rotation.
for a bodgy timing method, turn the dizzy until it idles fastest and smoothest (make sure vaccum advance disconnected and plugged) and then retard about 10degrees.
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
