Results 1 to 10 of 193
Thread: The 2cent Cabby
    Ballajura, W.A
    Was meant tobe putting head back on this weekend but has been put back a week! so decided to check the valve adjustment disc messurments so i can fugure out the size needed for the new cam if any at all!
    For anyone who dosent know hes what i did "im sure theres other ways but might help someone"
    As the camflowers were out already numbered in seperate bags so they go back on the correct valve. With a pair of vise grips (not the correct tool but worked) pulled the shim out to see the number underneth pic below
    Finding the size of the disc already in will let me know the thickness needed and how much its out if at all!
    Also as the shim kits are pretty expensive and hard to find i found 2 site where you can buy them seperatly or in kits lonked below.
    TOOL Page (¯`·.¸(¯`·.¸ ZDMAK SPECIAL TOOL STORE ¸.·´¯)¸.·´¯)
    Valve Clearance Discs
    Mine where 31mm in diamiter but not sure if this veries!
    Hope that helps someone anyway.
    Heres the Valve clearence spesifications table to
    Also sprayed my sills with stone protection today!
    Befor and after
    Oakleigh VIC
    There's a place local to me that does the shims too.
    PRECISION SHIMS AUSTRALIA | INLET SHIMS | EXHAUST SHIMS | VALVE SHIMS
    Handy if you need some thick ones for reground cams.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Ballajura, W.A
    Cheers for that Pete, tried finding Aus sites but only came up with motorbike shims
    Jun 2012
    Auckland, NZ
    I just read through this whole thread. Great work man! Can't wait to see it finished. Hoping to build a Cabby of my own next year
    NSW, Sydney
    Epic build thread mate, you should be proud of all your work. End product is a must see
    Ballajura, W.A
    thank you
    Aug 2012
    Blackmans Bay, TAS
    I have a couple of different cv boots if your still looking for one? 2 different styles, I'll post up a pic tomorow
