Results 1 to 10 of 193
Thread: The 2cent Cabby
    Ballajura, W.A
    Can anyone tell me where this vacume pipe goes?
    Its a 6mm pipe that comes thru the fire wall right next to the wiring loom, as mine a left hand drive it comes out just next to the clutch peddle.
    When i bought the car it wasn't connected to anything and was split. I have pulled it out and replaced it with a new pipe but have know idea where it connects to i think it was pushed in behined the fuse box but cant see anywhere it connects??????
    Pictures below.
    [/IMG]
    [IMG][/IMG]
    Jul 2005
    Newcastle, NSW
    It might be the one that connects to the back of the multifunction display in the dash? It is used for the miles per gallon economy.
    Ballajura, W.A
    As i dont have a MPG gauge, just the change gear display, so do i need it? and if not can i get rid of it?
    Perth. WA
    Ewen,
    most likely the vacuum pipe that connects to the LHD factory aircon switchgear, its located behind the dash where the levers & knob are.
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
