280mm cordoba discs???? Normal stock cordoba discs are 239mm. Maybe you meant 'corrado'? Grant still has a set of the 280's there i think if you wanted to try them...
So Luke why are you going from this tsr kit which is already 280mm to a VR6 setup of the same size? Is it just for the bigger calipers/pads?
Also as far as I know all the 280mm discs found on Golf and Corrado G60's, and Ibiza Cupra's are the same offset/bell height. I think maybe even the 280 VR6 are the same - except they are 5x100. There are some Golf 4 280mm discs in 5x100 too, but they are a different offset FYI.
Also Loon, which mk2/seat calipers are you talking about? The post 1989 16valve GTI ones are the only mk2 brakes that have removable caliper carriers. All other mk2 hubs and calipers have fixed carriers to the hubs and are completely different to the mk1 setup aren't they?
All the mk3 calipers will definately work with an adapter though.
I'd be very keen to get something made up like Pete says to give you the option to either extend the original mk1 GTI caliper out, or just use the mk3 calipers with a 280mm disc!
Cheers,
Wade
