Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: 280mm mk1 brake upgrade
    Feb 2006
    Perth Western Australia
    Guys awhile ago i installed a TSR 280 brake upgrade into my mk1 rally car and it works mint. Now i'm upgrading to VR6 280mm brakes and am trying to figure out what to do with the near new 280 upgrade kit. The Kit uses STD MK1 GTi calipers with special offest black diamond combination discs and a machined adaptor plate. Just seeing if people here are interested in getting some more adaptors machined up (probably donate the design to roccodingo) and i'll get in some more discs. Beauty of this package is excellent stopping power without needing to upgrade the master cylinder or booster to get the most out of it (for the record i did both as it is a rally car but works great on my dads diesel right now which is stock). This is a great low cost (about $350 ish) upgrade which really performs on the street and at the track. Let me know what you think.
    Luke
    77 Golf tarmac rally
    89 porsche 911
    80 Rabbit 4dr
    11 mk1 and 2\'s in various states of undress
    KEEPING THE BIG CUBES IN THE REAR VISION MIRROR
    I had a 270mm kit form TSR years ago. Awesome brakes. Are the discs not plain 280s, G60?
    Feb 2006
    yeah pretty sure the tsr caliper offset bracket requires a diff disc offset but i will investigate with stock 280mm cordoba discs and let you all know, much cheaper then if that works
    89 porsche 911
    80 Rabbit 4dr
    Oct 2005
    Nowra, NSW
    Does this make a big difference considering you are using the stock gti caliper setup?
    Quote Originally Posted by static1800 View Post
    It makes a huge difference, the brakes pedal feels weedy still but you can stop hard.
    Sep 2009
    Chillaxing in Tas
    I cant understand how though? your still using the same amount of contact area on those bigger disc's as you would be on a stock vented disc..
    Maybe there is a different caliper you could use to increase the contact area?
    <space for rent>
    Feb 2006
    OK time for a physics lesson guys, it is called moment of inertia or torque. The same force applied over a longer distance from the pivot leads to a greater torque being applied hence spacing the caliper further from the hub whilst applying the same force increases the torque, in this case braking torque, Think of it like using a spanner then putting a breaker bar on the spanner, much easier to apply greater force isn't it. This is the principle behind this brake upgrade as it spaces the caliper 50 odd mm further from the hub than stock. Yes the braking surface area doesn't change but hey it is like max spend of $300 odd and great bang for your bucks for almost twice the stopping power (well don't know for real but these things pulled up nothing like a mk1 GTi brake setup, pissed all over them. Proven to work so much better in competition.
    Yes putting bigger calipers on will again improve things but that adds big big cost as you have to custom machine your hubs, source calipers and then upgrade the booster and master cylinder. I'm trying to help out and give all mk1 golfers a cheap upgrade which will revolutionise the mk1 braking capabilities. The only reason i'm upgrading is to use that bit more of a braking surface area as my car is purely for racing and there a bigger still gains to made and hence time to be saved.
    This kit requires only mk1 GTi calipers to work and nothing else.
    89 porsche 911
    80 Rabbit 4dr
    Jun 2007
    Eastern Suburbs Melbourne
    I was just about to do some study (for uni), but it seems I've learnt my new thing for today already! (never actually though as to why bigger brakes were better)
    Was the $300 odd including the new discs and the spacers?
    i like volkswagens
    bigger mastercylinder also helps massivly with brake travel
    Velly
    '91 2.0 8v GTI
    Quote Originally Posted by DubSteve View Post
    I have wood thinking about you
    Camden, Sydney
    Can we use stock 280mm Cupra disks which have the 4 stud holes?
    I`d buy a couple of sets of adaptors so these disks can be made to fit a Mk1.
    I also have lots of those GTI calipers as they are used on SEATs and Mk2s, but I have no carriers for them.
