Results 31 to 33 of 33
Thread: 280mm mk1 brake upgrade
  1. #31
    Feb 2006
    Perth Western Australia
    plenty of options you can do cheaply using std VW gear. G60 280mm discs with a girling 54 caliper will do the trick. you can buy caliper adaptors for $50 on ebay. Remember to upgrade the master cylinder to a mk3 unit also mate. a 9" booster will also improve the braking response.
    77 Golf tarmac rally
    89 porsche 911
    80 Rabbit 4dr
    11 mk1 and 2\'s in various states of undress
    KEEPING THE BIG CUBES IN THE REAR VISION MIRROR
  2. #32
    Peregian Beach
    Bora Sport, what did you do to make that setup work? What size discs mate?[/QUOTE]
    That is the standard front end brake setup removed from my wrecked Seat Cupra. 280mm rotors. The rotors were replaced with near new pads as I recall not long before the car was written off.
  3. #33
    Perth. WA
    Quote Originally Posted by Browneye View Post
    They pull up fantastically well mate. They are a 54mm piston which is the same as a VR6 caliper, and the pad has excellent disc coverage.
    Are you seriously considering selling George? Is there another mk1 we don't know about?
    Caliper is the same as a VR6 Mk2 GTI ( G54) just the carrier bracket is different between VR6 and other models ( corrado etc ) - ( bolt spacing ), something to watch for ....
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
