Results 21 to 30 of 33
Thread: 280mm mk1 brake upgrade
  1. #21
    adelaide
    i would love to upgrade my mk1 brakes $350ish sounds ok where can i buy the kit from
    Quote Originally Posted by Volksee77 View Post
    Guys awhile ago i installed a TSR 280 brake upgrade into my mk1 rally car and it works mint. Now i'm upgrading to VR6 280mm brakes and am trying to figure out what to do with the near new 280 upgrade kit. The Kit uses STD MK1 GTi calipers with special offest black diamond combination discs and a machined adaptor plate. Just seeing if people here are interested in getting some more adaptors machined up (probably donate the design to roccodingo) and i'll get in some more discs. Beauty of this package is excellent stopping power without needing to upgrade the master cylinder or booster to get the most out of it (for the record i did both as it is a rally car but works great on my dads diesel right now which is stock). This is a great low cost (about $350 ish) upgrade which really performs on the street and at the track. Let me know what you think.
    Luke
    i would love to upgrade my mk1 brakes $350ish sounds ok where can i buy the kit from please let me now 0434615114
  2. #22
    Mar 2011
    Bunvegas, Western Australia
    TSR big brake kit for mk1 golf
    That's the kit mate.
    1976 VW Golf "Swallowtail" - Rallye Red (long term resto)
    2009 Pirelli GTI - Stg3 killer
    2009 R36 Passat - Daily baller
    You take corners on three wheels, and V8's can't catch you.
  3. #23
    Gosford Central Coast NSW
    I remember talking about this problem with Loon ages ago.
    I think there would be more merit in adapting the mk2/3 hubs to work well in the mk1 chassis - because then you can use all the easy bigger brake options without anything tricky.
    The main difficulty with this is that most of the mk2/3 hubs are for power steering, and have a short steering arm.
    I was thinking once upon a time that theres likely an off the shelf tie rod end you can buy that has an offset large enough to counteract the difference in moment arm to the hub somewhat. you could have slight quicker steering and better brakes.
    I dunno.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  4. #24
    Jan 2010
    Melb Westsideeeee
    Just reviving an old thread, any more update on running larger brakes on the mk1s, via an OEM option as opposed to buying kits?
    Anyone done anything over the years?
    - Brown U.S import 81 cabby
    - 88 Honda crx b18cr
  5. #25
    On mine I'm fitting 280mm disks off a Seat Cupra with callipers off an old Vauxhall or Opel. It's supposed to be a straight swap with no machining needed or adapter plates.
  6. #26
    Jan 2010
    Melb Westsideeeee
    I think from memory it was a calibra if Im not mistaken?
  7. #27
    Feb 2013
    Melbourne SE
    Quote Originally Posted by GeorgeMK1 View Post
    You are correct. This is my setup...
    Callipers and carriers are off a Holden calibra (opel/vauxhall import) v6 or 16v turbo (i cannot remember) and have enough room to accommodate for 288mm discs. Shame vw don't make em that big in a 4 stud.
    Here's a pic of the callipers
    and the necessary shoulder bolts to mount them (the carriers have a 12mm hole but the mk1 hubs require a M10)
    All else that is needed is some G60 corrardo discs.
    George, I'll whip a wheel off for you at the next mk1 meet and you can have a squizz, so you'd better get around to organising one
    EDIT: You'll need to get some mk4 polo break lines to connect everything up correctly. It's fairly self-explanatory
  8. #28
    Peregian Beach
    I have a complete set of front brakes from my Seat Cupra that I am keen to sell if anyone is interested. Near new rotors and painted calipers.280mm mk1 brake upgrade-image-jpg
  9. #29
    Jan 2010
    Melb Westsideeeee
    Jordan that's awesome man, how do they stop? So really its like a vr brake setup size then.
    Also, I will whip something up really soon man
    Bora Sport, what did you do to make that setup work? What size discs mate?
  10. #30
    Feb 2013
    Melbourne SE
    They pull up fantastically well mate. They are a 54mm piston which is the same as a VR6 caliper, and the pad has excellent disc coverage.
    Are you seriously considering selling George? Is there another mk1 we don't know about?
