Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 42
Thread: Is 240hp good for a 8v mk1?
    FYI - you can get 150bhp out of a 2.0 k-jet motor and run it all day long as an everyday car.
    still would love to know more about this 240bhp engine and what spec it is.
    Velly
    '91 2.0 8v GTI
    Quote Originally Posted by DubSteve View Post
    I have wood thinking about you
    Quote Originally Posted by velly_16v_cab View Post
    x2 until then, Im a sceptic (but happy to be proven wrong in this case!)
    Aug 2006
    Melbourne VIC
    I know a lot of 8v engines were used in Formula 2 in the late 80's early 90's.
    They would build them to rev like crazy and only run for a race meeting then need a strip down. Constant 9k limiter abuse in a 450kg open wheeler is epic win but having to strip down engines after evry race meeting not so win.
    Have a chat to this bloke and get him to build you a warm street engine.
    Or better still go and see Andrew Robison. He knows his stuff and im sure would be more than happy to help you out....
    Sep 2007
    i don't think it's especially impossible to build high power 8v motors...
    mkIIroc in the states pulled 150whp on a counterflow 8v built in his back yard.. standard JH head. i don't know if i trust the figures but they wouldn't be that wildly inaccurate.
    240hp even at the fly for an all motor 8v is definitely pushing limits though.
    87' MK2 GTI
    13' MK7 TDI
    Quote Originally Posted by jayjay View Post
    you dont see many g60's pushing out that sort of figure TBH
    Velly
    '91 2.0 8v GTI
    Jun 2007
    Eastern Suburbs Melbourne
    must be run on something other than 98. I'm thinking methanol, C16, AVGAS or something. and even then, I reckon it's pushing the limits.
    It'd be a race engine, and definately not streetable. (imo)
    i like volkswagens
    Sep 2007
    most definitely not a street engine... that rocco in the states i'm talking about is a home build, but it's a dedicated drag car. on methanol it puts out like 170ish whp. but i dont think he rebuilds it unless it breaks
    87' MK2 GTI
    13' MK7 TDI
    Mar 2009
    Empire Bay NSW
    240 hp for 5 sec before it goes BANG! agreed great things have been built in back sheds but more bad than good
    Mar 2007
    South Brisbane
    In this day and age word of mouth pretty much means nothing specially talking power and engines, before posting on any forum with this topic hard evidence is essential. But there is 2 sides to every story and the setup has not be listed as yet is it 2.0l ?? cross flow head?? no one knows, you can make good power numbers from a 8v 1.8 or 2.0 N/A, Turbo or Nitrous depending which path you choose will depend on what outcome. There are people out there with deep pockets and good knowledge but there is also dreamers
    Jun 2006
    Orange NSW
    I built an 8v 1.8l NA with the works years ago for street use it featured
    *0.40" oversize 11:1 compression pistons
    *fully balanced bottom end with knife edged crank, ultra light weight flywheel
    *schrick 282 degree cam extensive porting, polishing, match ported, 40.5mm inlet valves, 33mm exhaust valves, heavy duty springs, titanium retainers, adjustable cam gear.
    *twin 40mm webbers, ported & polished manifold.
    *custom extractors 4 into 1 with tuned length calculated to suit modifications, 2 1/2" mandrel exhaust straight through mufflers.
    *electronic ignition etc etc the list goes on...
    My point being with this engine on the dyno all tuned and carbies jetted by a reputable tuner specialising with webbers it put out shock horror 132whp... or around 160 flywheel hp at 6800rpm
    240 hp is possibly acheivable but it would take deep pockets and would not be streetable...
    Mk2 GTI 2 door 1.9l 8v turbo 1st mk2 1st engineered water vw nats 09
    Mk1 twin eng twin turb
    scirocco gti 2.1l 16v turb 6spd
    Audi A4 B5 1.8t
