Ah beauty that's awesome! Is this magazine available locally?
1979 Mk1 Golf GTi
1994 Mk3 Golf VR6
Good on ya mate! I actually test drove this car before you bought it off Matt at Camden GTI - FUN!
I like your approach in trying to keep her as clean and original as possible - keep up the great work!
- Mk2 Golf GTI 16v, 2-door, Tornado Rot, BBS RS, 1988 - SOLD
- E30 325i Coupe, Manual, Alpinweiss
- E30 325i Touring, Manual, Diamantschwarz x 2
- On the lookout for another E30 325i Coupe, Manual (red would be nice)...
Nice work Liam! Love the shots around Canberra
85' MKII GOLF GTI - GTI 85T - First cruise was 4000km in 2.5 days. It's Evolving!
06' MkV JETTA TDI - Stock To Shock
That is such a sweet looking MK1. Well done in keeping it original as I know I can't resist the temptation to modify a bit here and a bob there to make it more modern to drive.
1978 MK1 2.0 16v http://www.vwwatercooled.com.au/foru...-46488-70.html
1991 MK2 GTI 2.0 8v, white (RIP) and it's red replacement http://www.vwwatercooled.com.au/foru...gti-42078.html
1997 MK3 CL http://www.vwwatercooled.com.au/foru...ml#post1292061
2001 & 2002 Bora 4motion. http://www.vwwatercooled.com.au/foru...st-123823.html
Your not looking for modern, just reliable starting haha.
Congratulations on the article! It looks so good in those pics, it has come a long way since you have owned it.
My GTI has now gone to Mick's place for some love and attention. It has a warm start issue that needs rectifying (ie. if the car is warm and has sat for 10-15 minutes it won't start for another 45 minutes or so).
Fingers crossed Mick can remedy the situation for me while the missus and I try and remedy the debacle that our house reno/extension has become.
Do a serch on vortex for "hot start relay" if that is no avail message me here and I will scan and email you the wiring / relay etc. It was a problem with the 8Valve cars for ages ( heat soak from the engine once parked) has happened to me only a few times in the madness that is summer.
For an instant fix, remove the rubber banjo over the metering head, lift the air plate with pliers while cranking the engine, it will allow the fuel vapour to exit the injectors til fuel liquid comes out allowing the engine to fire. reassemble and drive. tooling is a screw driver and a pair of pliers as well as another person.
car is looking its usual brilliant self Liam.
Good luck with the house issue !!
Lots of MK 1 Scirocco's...
Cheers,
Grant...
