You also need to change the intermediate shaft, crank pulley, intermediate shaft pulley, oil pump drive gear and thrust bearing / cover ( where the 8V dizzy goes) use a 16v oil pump, and have piston oil squirters preferably in the *v block your using. Then there is the different timing belt, distributor , plug leads etc... list is near endless... plus you of course need to have the 16V head, cams, sprocket etc...Exhaust manifold / extractors have a different bolt pattern and the inlet manifold as you already have indicated.
Cheaper option is to buy a complete engine IMO.
Glad to see that you have your mind working on options though
Lots of MK 1 Scirocco's...
Cheers,
Grant...
