Page 22 of 29 FirstFirst ... 122021222324 ... LastLast
Results 211 to 220 of 285
Thread: 11/78 mk1 gls
  1. #211
    Aug 2009
    Problem with the switch is that I can't hang the under-dash carpet with it in the way.
    BTW, above pic makes me hate life. I was never aiming for Hellafendercrunch BS, was hoping they'd fit a heap more comfortably than that.
    Also, that pic is with a 15mm test-spacer. If 7mm less poke counts for anything, that's where it's going to be...
    I'll 'fit' the wheels once tires are on, that's when i'll make the big decision: whether to buy spacers and long bolts, or give up.
  2. #212
    Sep 2009
    Chillaxing in Tas
    ive got +16 13x6.5 on front.
    I had to flare out front guards "gently" with a big hammer, and then mod the crap out of the GTi arches to allow a little more rim to be covered. i still got about 3mm poke. but i still need to set camber and actually get rest of engine in,
    <space for rent>
  3. #213
    Aug 2009
    I haven't factored in camber at all really... Hopefully that will give some relief from 14x7 +7 (spaced).
  4. #214
    Mar 2009
    hellaflush! hectik
    78 2-door 1.8 KR 16v - twin dellorto's
  5. #215
    Aug 2009
    I put some blocks under the control arm and dropped it back down for a test fit. Silly me, they'll fit no worries with a guard roll because they pulled in heaps.
    Tires fitted. Last set of Federal 155/55's EVER, if i understand correctly. Suck me.
    And yes, fitment is a goer.
    (glad i'm not keeping track of what i'm spending on this POS...)
  6. #216
    Aug 2006
    Melbourne VIC
    So do you still need spacers?
  7. #217
    Aug 2009
    Yep, but it's not as Mexican as I thought it was going to be.
    Didn't want to have to butcher my guard because 80% of the time these wheels will be off the car.
  8. #218
    Sep 2009
    Chillaxing in Tas
    Quote Originally Posted by Jace View Post
    Yep,I wanted to butcher my guard because they will be on 100% of the time.
    Fixed it for you
    <space for rent>
  9. #219
    Aug 2009
    Ha not likely. Car will be a fair bit lower on those wheels too.
  10. #220
    Jan 2008
    Strathfield,Sydney
    76 Scirocco
