Can you get the grinder out of the brake caliper?
I know a few people have had to give the brake calipers a quick lick with the grinder to avoid running spacers...
If i tried to AVOID running spacers there wouldn't be much caliper left...
bit of both maybe![]()
Before adjustment:
5+3mm slip-on spacers (with longer bolts obviously)?
Got Poke?....
<space for rent>
Just a bit.
Did a bunch of stuff today. While I was test fitting one of the rims my old man came out, looked at the car front-on and saw the poke and just goes "nope, not gonna work" shaking his head.
Made test-spacers out of wood, 9mm to be exact. Probably gave me 3 or 4mm of clearance between the caliper and the wheel.
Also made a new brake light switch. It looks dodgy but I assure you, I could have done it a lot worse. Need to do it again with a welder though.
And to whore my nice carpet:
Funny enough i did mine the same
and yeah, good luck on front rims![]()
<space for rent>
