Page 16 of 29 FirstFirst ... 6141516171826 ... LastLast
Results 151 to 160 of 285
Thread: 11/78 mk1 gls
  1. #151
    Gosford Central Coast NSW
    the left tie rod is non-adjustable from factory, but you can't buy them. you replace a worn out lefty with a right, which isadjustable. if you have lowered your car, you really should put an adjustable lefty on, so that you dont have to move the steerin wheel off centre.
    I have never needed to pull the rack to do the rack end boots, but what you do need is 2 shifters... cheap ones. Cut the handle of one off about 6" long so you can move it a little way.
    simply use the long one on the rack end to hold it, and the short one to unlock the locknut. you can get a bit creative with your under-car positions.
    I always do this from below, with the car on jackstands.
    finally, a little grease inside the new boots before you put them on is a good idea, always clamp the boot tight with a massive cable tie (unless you have the tool to do those clips) and if you're thorough, get a wheel alignment afterwards (unless you manage to do it without taking off the tie rod, just by sliding the boots on over the balljoint on the end.)
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  2. #152
    Aug 2009
    You're talking about the inner ball joint right, with the massive flat sections to fit large spanners? I'll have to buy some ****ty shifters tomorrow then.
    Thanks for that.
  3. #153
    Jun 2007
    Eastern Suburbs Melbourne
    you can just slid them off, but this is a little bit more difficult. I'ts not too hard to remove the whole tie rod assy though. good learning curve!
    i like volkswagens
  4. #154
    Aug 2009
    Passenger side was a bitch. Doesn't have a flange bit to put a cable tie behind so I used two boots on that side because I cut one down a little bit too much.
    It's all ready to go now though.
    Washed it for the first time since I bought it. Paint is a bit worse from sitting for so long, need to get a buffer!
    All the missing bits I have at least one of that I'll put on after paint resto/new paint in some places.
    RWC and rego on monday assuming everything goes well.
    What got me worried is that the bloke at Vicroads mentioned I need proof of former australian rego, which I don't have... Never rego-ed a car from scratch before.
  5. #155
    Jul 2007
    Launceston
    Looking preeeettty
    Here - I'm pretty sure there is an option in the forms you fill out to say if you know of any previous regos or not... I just check the "No" box and haven't had any issues so far, but it's more than likely different in Vic...
    I'm going to the pub... I may be some time...
  6. #156
    Aug 2009
    Yeah, Tasmania seems pretty 'lax on rules n stuff. Guess I'll find out on monday.
  7. #157
    Jun 2007
    looking good Jace, GL with vicroads on monday.
    These are the only things you should need, even for a 'new' rego.
    Proof of ownership (inc vehicle details, previous owner details etc) RWC and the form you have to fill out. it's all listed on the Vicroads website
    i like volkswagens
  8. #158
    Aug 2009
    Thanks mate.
    Okay sweet. I got one of those stern old jerks at vicroads when i picked up a permit, he got me all worried.
    Sweet as!
  9. #159
    Aug 2009
    VicRoads ain't ****.
    Oh, I have some wheels on the way.
  10. #160
    Jun 2007
    nice, on both accounts!
    i like volkswagens
