Results 1 to 10 of 20
Thread: 1.8GTI motor in Mk1?
hiho 1.8GTI motor in Mk1? 29-03-2010, 12:58 PM
dubai gti Best to either go for a... 29-03-2010, 07:26 PM
Peter Jones It'll pretty much bolt... 29-03-2010, 08:29 PM
Peter Jones Oh, forgot to mention that to... 29-03-2010, 08:30 PM
Jarred if you have all the Kjet... 29-03-2010, 09:04 PM
    Apr 2006
    Melbourne, Victoria
    Hello all,
    I'm after some pointers for fitting a 1.8GTI Cab motor in a Mk1. No, I havent gone off diesels, me and James (hessiethecrab) will be instaling this motor in his Mk 1. We have the manifolds, fuel injection system, ignition, oil cooler, radiator, gearbox and gearbox mount.
    What we dont have is a fuel return line, drive shafts or any idea how to get the fuel injection working.
    We would probably prefer to replace the fuel injection with a carburettor. What would be reccommended for this motor/car combo? WHat else do we need for this installation?
    Cheers everyone!
    Matt
    Beige 79 Mk1 GLD White 76 Mk1 LS 3 door
    White 68 Alfa 1750 Berlina Champagne 91 Alfa 75
    Red 09 9N3 Polo TDI White 2010 Skoda Octavia Combi TDI
    Feb 2008
    Melbourne.
    Best to either go for a twin-weber set-up or what I run..a single 44IDF Weber and Oval Ramflo filter.....which is still pretty thirsty, but sounds great
    Children(VW) who have left home, among others:1966 VW 1300 Deluxe Bug(Harbour Blue)1966 VW 1300 Steel Sunroof Bug(Ruby Red), 1971 VW 1600 S Bug(White) 1972 VW 25th Ann. Bug(Avocado) 2000 VW Golf Mk IV GTI 3 door(Metallic Black Magic), 1985 VW Golf Mk 1 GLS Cabriolet (Metallic Gun Metal) Current: 1985 Mercedes Benz 280CE Coupe(Midnight Blue)
    Oakleigh VIC
    It'll pretty much bolt straight in. Is it a K-Jet or EFI motor? There's a few differences in what you have to block up depending on which you've got.
    There's a bit of info in my Ziggy thread which was a GLD to Cabrio 1800 conversion. There's also a few other bits and pieces kicking about the place.
    Keep asking questions and I'll hunt down the photos and posts for you.
    Ziggy's thread. http://www.vwwatercooled.org.au/newf...ad.php?t=38301
    My wreck to racecar thread's got a lot of info in it too along those lines (Link's in my sig below)
    Easiest choice of carb for a daily is a twin barrel progressive like a Weber DGV,DGAV DCD etc on a Passat TS manifold. All you need to feed it is one fuel line and an electric pump, a Facet monoblock unit or similar should do the trick.
    Bigger carbs need more fuel, if you go up to single or double sidedraughts then a Carter rotary vane pump is the answer.
    Grab a couple of shots of you new motor and your destination engine bay and we'll be able to see what's going on a point you in the right direction.
    Pete
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Oakleigh VIC
    Oh, forgot to mention that to put an 1800 into a MK1 you need a GLD top radiator hose. The bottom one is the same.
    Pete
    7? MK1 Caddy
    12 Amarok
    Jun 2007
    Eastern Suburbs Melbourne
    if you have all the Kjet injection gear, it's not too hard to put it into the diesel (since it was meant to be in a mk 1 after all)
    so don't rule it out straight away. I'd only install the Kjet if I knew the system was in good working order before hand though.
    i like volkswagens
    Sep 2007
    make sure you actually have every single bit of k-jet gear too though.
    otherwise ---> up the creek no paddle
    87' MK2 GTI
    13' MK7 TDI
