Results 1 to 5 of 5
Thread: 1.8 l 8
83golf 1.8 l 8 23-06-2010, 01:52 PM
Jarred there are cross flow 8V... 23-06-2010, 04:00 PM
roccodingo big job putting a 16 valve... 23-06-2010, 06:35 PM
Henri Bahn Brenner Motorsport -... 23-06-2010, 07:09 PM
83golf any ideas who sell the 8v... 26-06-2010, 06:17 PM
    Apr 2010
    redcliffe, brisbane
    1.8 l 8
    Hi guys i recently purchased a 1.8l 8v and need some info. will the 16v head fit and run on the 8v block or can you purchase cross flowed heads??? also where is a good place for parts as i would like to do a full rebuild thanks.
    Jun 2007
    Eastern Suburbs Melbourne
    there are cross flow 8V heads. mk 4's have crossflow engines (both 1.6 and 2.0 iirc) and the ABA was a crossflow 2.0L 8V from the states.
    I'm not sure regarding 16V head on 8V bottom end. Either way, it would probably be easier to get a complete 16V than just a head alone.
    i like volkswagens
    Perth. WA
    big job putting a 16 valve head on an 8 valve bottom end, you need change the intermediate shaft, all the timing belt gears, TBH as jarred suggested its easier to go with a 16 V engine to start with.
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    Nov 2009
    Hobart, Tasmania
    Bahn Brenner Motorsport - MkIII 2.0L ABA 16V Head Conversion Kit
    This has the bits required for a 8v to 16v head swap apart from the head. Is this kit still applicable to 1.8?
    77 Mk1 w/2E Engine (no longer for sale)
    Apr 2010
    redcliffe, brisbane
    any ideas who sell the 8v cross flow head??
    Mk1 76 donor car
    Mk1 GTS 83 SA import,
    MK1 76 project
