Results 1 to 10 of 16
Thread: 1.8 injected to carbi conversion
    Feb 2010
    perth, western australia
    hey guys
    im have a 1.8 fuel injected motor lined up for my mk1
    im not sure what type of injection it is, but i was thinking for simplicity sake i will put my weber carbie on it
    im just wondering what is required and if it is as simple as putting the carb on and tuning it up.
    i have done a search of the forum but i have found any threads on it.
    if anyone could link me to a conversion thread or give me some sort of information it would be amazing
    As a minimum, you'll need a carb from an 1800 motor, I doubt one of a 1600 would have the capability to provide enough fuel.
    Sep 2009
    Chillaxing in Tas
    Your on the money Gav
    The stock solex is crap, go a weber setup.
    Depending on the Injection setup, you will have to block the holes in head, its a matter of using a half inch i think it is Hex key and undo the jacket bits, slap a 5 cent piece in (thanks Pete for this Tip) bit of silicon and thread the jacket bit back in.
    <space for rent>
    Feb 2010
    yup i already have a weber set up on the 1.6 so ill use that, it may need to be jetted but i will find out. awesome i think
    keeping it carbie will be easier then trying to get the injection to run in my car.
    Sep 2009
    Chillaxing in Tas
    yeah it should do,
    if the carb ran great on the 1.6L, take note of what jets you have and maybe go up one size in the main jets and air correctors to compensate for the extra Engine Size
    <space for rent>
    I'm looking at doing the opposite. Give me fuel injection over carbies any day.
    Feb 2010
    yeeeah too much effort in regards fuel pumps and air flow metres
    Feb 2010
    ok so its a kjet 1.8 out of a 1990 cabby karmann... is it worth keeping the kjet on it or just chuck my carbi on
    Fuel injection (when setup properly) will always be better than carbies.
    Carbies will always be easier to fix when something goes wrong. Something to consider if you drive where the NRMA (or local equivalent) take a long time to reach you. Or if you like doing everything on your car yourself.
    Paul
    Aug 2008
    SYDNEY
    buy this and use the engine.
    unlicenced Audi E80 sedan | eBay
    2008 POLO GTI - SOLD
    2005 MkV Golf GTI - couldn't resist
