Results 1 to 6 of 6
Thread: Wiring on warm up reg and cold start injector for k-jet, 16v.
seventhirteen Wiring on warm up reg and... 01-10-2011, 05:18 PM
RedMk2Gti Thermo time switch see... 01-10-2011, 06:19 PM
Peter Jones and this thread here... ... 01-10-2011, 06:20 PM
seventhirteen Ah yes thats what I needed.... 01-10-2011, 08:52 PM
RedMk2Gti IIRC, mk1 never has 16v... 03-10-2011, 08:14 AM
roccodingo Temp sensor as in the Thermo... 03-10-2011, 08:36 PM
    Aug 2011
    Hornsby, NSW
    Pulled off the plug on the warm up reg and cold start injector so I could fix up the wiring cause it was nasty! So nasty that I dont know how it all is meant to be hooked up.
    So the cold start injector plug only has 2 wires coming from it, 1 was to earth and the other to nothing. The one on the warm up reg also has 1 earth wire, a wire to the starter motor and another wire that ends in a plug thats been taped up and goes nowhere. So basically, my question is, whats the cold start injector wiring originally meant to be hooked up to?
    Thermo time switch
    see figire 15.1.7 in here Auto-Solve Diagnostic Assistance
    Oakleigh VIC
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Aug 2011
    Hornsby, NSW
    Ah yes thats what I needed. Just 1 more question. I got a 16v in my mk1 golf. Would anyone know where the temp sensor and the aux air valve would be?
    IIRC, mk1 never has 16v k-jet. Is yours retrofitted with Mk2 16v k-jet setup ?
    post up your engine bay pic, then some one may be able to spot it.
    Perth. WA
    Quote Originally Posted by seventhirteen View Post
    Temp sensor as in the Thermo time switch ?? it goes on the dizzy end of the head.
    Aux air reg ?? , from memory the 16V's use the Idle stabilising valve set up ( definately on the US CIS-E models, not sure about the early european cars tho ). My factory 50 mm Scirocco manifold has the lug cast in for the aux air valve but it was never machined.
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
