Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: 1.1 southafrican to 1.6lt conversion
    Aug 2009
    I sort of want to go 1.6 to 1.1, just because the little blocks and positioning looks awesome!
    Perth. WA
    The 1.1 and 1.4 gearbox is different to the 020.
    You will need a 4 or 5 speed box from a 1.6 or 1.8 Golf.
    Rack is probably the same, shifter is different and shift bracket will be needed from a 1.6.
    Well thats going to make a bit more work for him to do then
    Parts available cleb if ya need them.
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    Feb 2010
    perth, western australia
    yer so i have had a really good look over everything, and i def need a different linkage, not sure if that means a different shifter too, grant i got my hadns on a mount for free, but i think i may need to get the linkage off you, i will see what i can dig up. the rack is fine, im going the 1.6box too so i have the corrent mount for that, i need a front engine mount tho cos the starter is on the opposite side on the 1.1s, does anyone know if the wiring needs to be mucked with much? i imagine it quite straight forward.
