Page 6 of 6 FirstFirst ... 456
Results 51 to 52 of 52
Thread: Xenon on 77TSI?
  1. #51
    Pacific Paradise QLD
    Quote Originally Posted by nomadx38 View Post
    They have washers to prevent the dirt, dust and grime creating excess glare from the Xenons high lumen output. The cleaners are just a high pressure jet that blows most of the stuff off. Bugs that have dried on though will not come off...
    Usually the washers are set to clean the headlights whenever you clean the windscreen (I guess they assume that if you are cleaning your windscreen because it has dirt on it so does your headlights)
    The manual says every 5th time
    The ADR Rules state that washers and self leveling is mandatory for lights above a certain light output I think it 2000 lumens????
    So if your lights are below that they would be legal if not No they arent
    I also read they may only be installed in vehicles of which a model has HID as standard.
    So you couldnt legally put them in a Mk2 Cortina for instance as no Cortina ever had them.
  2. #52
    Jun 2008
    Ringwood, Victoria
    Xenon on 77TSI?
    Just as a follow up, the Subaru XV does have xenon lights in reflector housings BUT they also have auto leveling (as per the ADR) and headlight washers, again, as per the ADR.
