Would anyone know if a workshop manual is available anywhere for 6r Polo?
Can anyone advise me on how to remove the plastic shroud which tucks under the bottom of the windscreen and covers the strut towers? I need to gain easy access to the top strut bolts on top of towers, in view of fitting H&R springs.
Kind regards
VEEEUU
If anyone can post up the procedure for doing this i'd also love to know as I need to do this also.
Thanks![]()
MY13 Polo GTI | 5 Door | Candy White | Sunroof & Bi-Xenon Factory Options
Can anyone help me out? How do you remove the plastic which covers strut bolts.
You can download a fairly comprehensive manual from ERWIN have to subscribe and pay 25 Euros for a 24 hour use and you can download all the manuals you want for just any VW. They come in sections like exterior body, Interior, Brakes, Suspension etc
I have most of the Polo ones but not the exterior body section
Would the exterior section cover how to replace the lower plastic panel (beneath the numberplate) on a TDi Comfortline. I damaged mine turning into a driveway too fast, and VW penrith want $300 for the part, and $170 to fit it!
If it seems simple enough i might attempt doing the fitting myself!
Cheers Guys
MY13 66tdi polo 'ocean blue', DSG. Comfort Pack, Sports Pack. RNS510 installed. Parking Sensors installed
If its the black bit with the little air dam type piece it just pushes in with clips I did a similar thing and it went back in OK
