It could be something on the windscreen itself....
Hi all
As the title suggests, the driver side wiper blade shudders even when it is raining. A change of blade doesn't help, should I get the wiper arm pressure checked or could I be looking at a faulty wiper arm?
I have cleaned the windscreen every which way, doesn't make a difference
Clean your wiper blades thoroughly or replace them, if that doesn't work, you can get windscreen polish it could be a film of crap on it that windex wont remove
sometimes the wiper arm spring pressure changes giving this issue or if the arm is slightly bent
VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150BRISBANE / GOLD COAST
Had same problem since just after car was new $75 of new blades fixed it but its back after a year Car only done 15000 in 4 years
The passenger side doesn't do it, which makes me think it might be the driver's side wiper arm.
Same as mine The blade doesnt swap direction for some reason it comes up with the blade surface leading instead of trailing if you get what I mean and so it shudders
Shouldn't have to polish the windscreen to make the wiper blades work correctly, surely?
Could also be an arm pressure issue, it might be pressed too hard against the glass so the blade doesn't flip over.
I contacted the dealership from where I purchased the car for advice, explained the issue and they responded that they can definitely check the wiper arm pressure. Good to know either way if the arm is bent or not, as I said it is only happening on the driver's side so I don't see a dirty windscreen being the issue.
