Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: Wiper shuddering even in the rain
    Apr 2008
    Blacktown NSW
    Hi all
    As the title suggests, the driver side wiper blade shudders even when it is raining. A change of blade doesn't help, should I get the wiper arm pressure checked or could I be looking at a faulty wiper arm?
    It could be something on the windscreen itself....
    Apr 2008
    Blacktown NSW
    I have cleaned the windscreen every which way, doesn't make a difference
    Mar 2014
    brisbane
    Clean your wiper blades thoroughly or replace them, if that doesn't work, you can get windscreen polish it could be a film of crap on it that windex wont remove
    Mar 2013
    Brisbane QLD
    sometimes the wiper arm spring pressure changes giving this issue or if the arm is slightly bent
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Pacific Paradise QLD
    Had same problem since just after car was new $75 of new blades fixed it but its back after a year Car only done 15000 in 4 years
    Apr 2008
    Blacktown NSW
    The passenger side doesn't do it, which makes me think it might be the driver's side wiper arm.
    Same as mine The blade doesnt swap direction for some reason it comes up with the blade surface leading instead of trailing if you get what I mean and so it shudders
    Jan 2013
    Brisbane, QLD.
    Quote Originally Posted by metallibanger05 View Post
    $5 polish, try it on your windscreen, usually fixes this issue.
    Apr 2008
    Blacktown NSW
    Quote Originally Posted by The One View Post
    Shouldn't have to polish the windscreen to make the wiper blades work correctly, surely?
    Could also be an arm pressure issue, it might be pressed too hard against the glass so the blade doesn't flip over.
    I contacted the dealership from where I purchased the car for advice, explained the issue and they responded that they can definitely check the wiper arm pressure. Good to know either way if the arm is bent or not, as I said it is only happening on the driver's side so I don't see a dirty windscreen being the issue.
