Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Will these wheels fit a 6R Polo?
    Hey Guys,
    will these wheels fit a 6r Polo GTI?
    They are off a Golf 15"
    What to run them with winter tyres and fit snow chains to them.
    Oct 2010
    Melbourne, VIC
    Golf IV I assume? If so, then the PCD and offset will be fine but will 15" clear your brakes? If they front rotors are 288mm, it should be OK but any larger and the won't fit.
    Resident grumpy old fart
    according to this website: Steel wheel Road wheel O.E.M. Replica wheel
    1997 VW Golf are 15X6
    5H/100 PCD
    +38 offset
    57mm bore
    VOLKSWAGEN GOLF IV 1997/AUDI
    what size front rotors does my GTI have?
    Jun 2008
    Ringwood, Victoria
    288mm.
    sweet looks like i am good to go. Spare set of wheels with winter tyres probably 195/75/15 and more readily available snow chain sizes rather than the expensize Summit K chains is what i am going to do.
    Jun 2008
    Ringwood, Victoria
    Not sure on that mate, minimum size on the Mk4 golf GTI with these same rotors is 16" due to the brake caliper. I'd say don't do it, just in case you get stuck with wheels that don't fit.
    Oct 2010
    Melbourne, VIC
    I have a couple of sets of 15" 5/100 wheels sets if you want to test
    Mar 2011
    Netherlands
    15" will fit, it's close but they do fit
    edit: pic to go with the talk
    Too late brought them !!
    Quote Originally Posted by PoloDave View Post
    What did the steelies come off? And how much you pay?
