Originally Posted by
route
that should be due to one side having more caster then the other...
That can cause that feeling but the casters are within 0.25 degrees of each other so I doubt that the issue.
rani-kirti: I recall that one of your aligners pulled the steering wheel off to centre it? (yes/no/maybe??) possibly it's that combined with a variable rack ratio (I don't know what Polos have?
Turn the wheel all the way to the extreme left lock. Then count the number of turns to go to the extreme right lock. Divide by two and turn back that number of turns. This should find the mid-point of the steering rack & the steering wheel should be straight & level. If it isn't then they need to get the steering wheel centred in relation to the steering rack and then adjust the tie rods so that the toe is correct & the steering is straight/level when driving.
Apart from that I can't offer any advice other than to stop driving your friends cars as they will always feel different to yours.
