first off thanks to all for help and suggestions, especially brad....
So last week i went to my dealer workshop for the sub frame alignment. they lifted the car on a lift and un did 4 bolts and moved/skewed the the sub frame in such a way that the front left tyre moved a bit forward and the front right moved a bit backward at the same time.
after re tightening the sub frame i went for a long extended test drive with my service advisor over a variety of roads and magically the car was running straight. it was a big relief after 4 months of going to many different alignment shops to solve this left pulling problem.
aligning the sub frame made the steering wheel a bit crooked which my service advisor fixed by removing the airbag and adjusting the steering with a tool and it become straight.
then i went to the hunter guy again for a realignment to be double sure and got a print out from him which i have posted below.
1. before sub frame alignment the caster value on the front left was RED and post sub frame alignment the caster value on the front right is RED. Camber still seems less on left than right post sub frame alignment. Is that OK ? Does sub frame alignment only adjust the Caster or Camber too ?
But here is my confusion.....
i have 2 sets of tyre.
my car came with 185 65 15 oem. i had upgraded to 205 55 15 the very next day. when i went to the dealer i had the 185 65 15 oem tyres on and post sub frame alignment it solved the left pulling problem.
a few days back i re installed the 205 55 15 and to my dread the left pulling has come back. i went to the hunter guy again and he tried a ton of stuff like left to right and front to back swap but the left pulling on the 205 55 15 remains.
2. Could it be that my 205 55 15 are faulty ? OR could it be that i need more sub frame alignment to make the 205 55 15 go straight ?
thanks.
