Page 9 of 13 FirstFirst ... 7891011 ... LastLast
Results 81 to 90 of 125
Thread: Why you Cannot do a "Wheel Alignment" on the 6R polo
  1. #81
    Jun 2014
    India
    We don't really have specialist suspension shops here where i live. the hunter guy does have hunter elite hawkeye which i believe is truly world class but he said to adjust any caster/camber you have to go to vw workshop.
    also thanks for your replies... it gives me a bit of hope to solve this issue. yes we drive on the LHS of the road. i'm going to another vw workshop to try to get this sorted.
    But looking for some clarity on the above replies as i want to be armed with maximum knowledge of what is possible before i go to the vw workshop....
    1. is the subframe and front cross member the same thing ?
    2. are you suggesting the front cross member on the left side be shifted slightly left & skewing it slightly clockwise..?
    So it indicates that 2 movements are possible
    a. shifting it left or right
    b. skewing it clockwise/anticlockwise
    Will this affect both caster and camber or only one of them ?
    If the above movement alters both caster and camber then i believe doing so will increase the caster on the left side and
    simultaneously decrease on right side and also increase negative camber on left side and decrease on the right side. Is that correct ? And that will make the car then go straight ?
    while researching i came across another member "pologti18t" quote below
    "it doesn't change the overall camber... Just the difference between left and right."
    What does this mean ?
    Warm Regards,
    Rana.
  2. #82
    Erskineville, NSW
    Quote Originally Posted by rana_kirti View Post
    He doesn't know what he's doing.
    It's not hard, undo the subframe bolts & lever it around a bit.
    yes it is
    There is one front x-member/subframe. It runs across the width of the vehicle underneath & slightley behind the engine. Look in Post #1 of this thread. page 128 of the workshop manual image (print it out!). If the mechanic is standing underneath the vehicle looking forwards then the X-member needs to be pushed left and forwrd on the LHS and rearward on the RHS. They'll have to experiment a bit.
    Yes. There are 4 bolts. The shaft of the bolt is about 8mm diameter. The hole is about 12mm diameter. So there's some wiggle room.
    You're alignment guy will work it out when he realises it can be moved.
    You want between 0.5degrees & 1 degree caster on the Left than the right - the actual figure doesn't matter that much. On yours, if you can get the Left at 4.4 & the Right just under 4 I'd be happy. Ideally L4.5/R4.0 Sorry, I'm talking in decimal degrees. Can't get my head around degrees & minutes. 30minutes = 0.5 degrees - you do the math.
    ideally you want between 0.5-1 degree extra negative camber (inward lean at the top) on the LHS than the RHS. The set-up is like a trapezoid so as you move the subframe L<->R it takes away from one side & adds to the other.
    You have only 0.5degrees total camber so not much to play with as you need to maintain negative camber on both sides. Aim for L-0.3---0.4 / R-0.2--0.1
    [COLOR=#333333]"it doesn't change the overall camber... Just the difference between left and right."
    it's a trapezoid and you are shifting the lower line left & right
    Why you Cannot do a &quot;Wheel Alignment&quot; on the 6R polo-maxresdefault-jpg
  3. #83
    Jun 2014
    India
    thanks a ton brad.... I'm going to my dealer today who has agreed to work the sub frame. hoping for the best.
    could you also take a moment to look at the Hunter report which shows the rear axle left camber in RED. what does that mean ?
    cheers
  4. #84
    Erskineville, NSW
    Back left is leaning in at the top. Spec is 1d17m-1d37m (call it 1.25-1.6) and your at almost 1.75 which isn't terrible. There's no factory adjustment for camber at the rear and as I said previously, one of the machines needs calibrating as it's within spec on the dealership machine.
    Don't get too hung up on specifications. What is more important is that the vehicles steers straight, is stable around corners & isn't getting bad tyre wear patterns.
    You can undo the mount bolts for the rear subframe/suspension units & try & wrestle them into a better spot & re-clamp the nuts but affect on camber is negligable. It's more to even out toe & get a better thrust line.
    There are aftermarket shims available for the rear.
  5. #85
    Jun 2014
    India
    Update post Sub Frame Alignment.
    first off thanks to all for help and suggestions, especially brad....
    So last week i went to my dealer workshop for the sub frame alignment. they lifted the car on a lift and un did 4 bolts and moved/skewed the the sub frame in such a way that the front left tyre moved a bit forward and the front right moved a bit backward at the same time.
    after re tightening the sub frame i went for a long extended test drive with my service advisor over a variety of roads and magically the car was running straight. it was a big relief after 4 months of going to many different alignment shops to solve this left pulling problem.
    aligning the sub frame made the steering wheel a bit crooked which my service advisor fixed by removing the airbag and adjusting the steering with a tool and it become straight.
    then i went to the hunter guy again for a realignment to be double sure and got a print out from him which i have posted below.
    1. before sub frame alignment the caster value on the front left was RED and post sub frame alignment the caster value on the front right is RED. Camber still seems less on left than right post sub frame alignment. Is that OK ? Does sub frame alignment only adjust the Caster or Camber too ?
    Why you Cannot do a &quot;Wheel Alignment&quot; on the 6R polo-img_20141029_120621-jpgWhy you Cannot do a &quot;Wheel Alignment&quot; on the 6R polo-att_1414564759255_20141028_121249-jpg
    But here is my confusion.....
    i have 2 sets of tyre.
    my car came with 185 65 15 oem. i had upgraded to 205 55 15 the very next day. when i went to the dealer i had the 185 65 15 oem tyres on and post sub frame alignment it solved the left pulling problem.
    a few days back i re installed the 205 55 15 and to my dread the left pulling has come back. i went to the hunter guy again and he tried a ton of stuff like left to right and front to back swap but the left pulling on the 205 55 15 remains.
    2. Could it be that my 205 55 15 are faulty ? OR could it be that i need more sub frame alignment to make the 205 55 15 go straight ?
    thanks.
  6. #86
    Pacific Paradise QLD
    Try taking the tyres off the rims and in and outing them
  7. #87
    Erskineville, NSW
    He should set the wheel straight ahead & then adjusted the tie rods underneath.
    I can't work out why you'd do this if the car had been fixed.
    Subframe adjustment will do both angles but I'd guess they've done what they can. There's only so much movement available.
    Don't worry about the caster reading - it's not a tyre wearing angle.
    Why on earth would you get it fixed with one set of tyres & then fit another set? The alignment is to fine tune the chassis angles and also to compensate for any run out that the tyres might have.
    What you've done is like having a misfire in an engine & getting it fixed & then puting another engine in and wondering why it's misfiring again.
    thanks.
    They might have excessive run out but usually a L/R swap at the front will fix that. What brand are they? Are they directional or asymmetrical?
    When they jack up the front where are they puting the jack?
  8. #88
    Jun 2008
    Ringwood, Victoria
    thanks.
    Guys could we maybe put this into a "why is my car pulling to the left" thread rather than "why you cannot do a wheel alignment on the 6r polo"? I am going to clean this thread up and remove any non-relevant posts so I suggest we start a new thread.
  9. #89
    Erskineville, NSW
    It's the same subject Gavs - just a different answer.
    As I've said before, you can do an alignment if you're willing to work at it. I know you don't agree with me but even the manual says it can be done.
  10. #90
    Apr 2008
    Blacktown NSW
    I just had the front toe checked and adjusted on my 6R (it was a little bit out), and have found the steering to be a lot more sensitive to road camber etc.
