Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Why wont my camera work
    May 2012
    As most of you would be aware i made the bracket to place the golf camera in the polo. Since then i have installed a thew RVC for friends (and friends of friends) with out a drama. but had not got around to doing my own before i had to leave for work for 2 months.
    So now that im back i finally got around to installing my own. it all went quick and smooth did the coding and then went to give it a spin. I got nothing. the camera poped out and the screen went to the black one with the writing at the bottom. so i satrted to process of diagnosing. Plugs. tick. wiring. tick (even check the continuity from front to back) so i did a VCDS scan and it was all red NAV, CAN, radio. media player, telephone, Cent electrics.
    i am baffled. i unplug the camera, reset and rescaned but still the same. everthing is still working like before (besides the camera).
    Any help would be appreciated. alternatively if there is anyone in hobart that has a camera they havnt installed yet and could lend it for ten minutes to check in exchange for help with there installe
    here is the log i did.
    Sunday,16,December,2012,17:33:02:09411
    VCDS Version: Release 11.11.4 (x64)
    Data version: 20120807
    Chassis Type: 6N0
    Scan: 01 02 03 08 09 15 17 19 25 2E 37 44 56 77
    VIN: WVWZZZ6RZCY239359
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    2E-Media Player 3 -- Status: Malfunction 0010
    37-Navigation -- Status: Malfunction 1010
    44-Steering Assist -- Status: OK 0000
    56-Radio -- Status: Malfunction 1010
    Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
    Part No SW: 6R0 937 087 K HW: 6R0 937 087
    Component: BCM PQ25 H+4 H46 0254
    Revision: BF046001 Serial number: 0434 068120397
    Coding: 3CB02BAF08A3000001380800252B0ED100C0410F6006000020 0000000000
    Shop #: WSC 12469 483 00190
    VCID: 4581E91ACC852530523
    Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
    Component: RLS 150212 05 54 0403
    Coding: 03302D
    Subsystem 2 - Part No SW: 6R0 959 802 AB HW: 6R0 959 802 AB Labels: 6R0-959-802.CLB
    Component: J386__TSG_FT 008 1611
    Coding: 18BC30
    Subsystem 3 - Part No SW: 6R0 959 801 AD HW: 6R0 959 801 AD
    Component: J387__TSG_BT 008 1611
    Coding: 18BC30
    Subsystem 4 - Part No SW: 5K0 959 542 HW: 5K0 959 542
    Component: E221__MFL-TAS H08 0010
    Coding: 830000
    Subsystem 5 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
    Component: J388__TSG_HL 008 1611
    Coding: 18BC32
    Subsystem 6 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
    Component: J389__TSG_HR 008 1611
    Coding: 18BC32
    2 Faults Found:
    00901 - Back-Up Lamps
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 209
    Time Indication: 0
    00907 - Intervention load Management
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 6
    Fault Frequency: 11
    Reset counter: 170
    Mileage: 4110 km
    Time Indication: 0
    Date: 2008.14.07
    Time: 14:32:58
    Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
    Part No SW: 6N0 909 901 HW: 6R0 937 087
    Component: GW-K-CAN TP20 H46 0254
    Revision: BF046001
    Coding: 002300
    VCID: F0EFE8CE23875098515
    3 Faults Found:
    01044 - Control Module Incorrectly Coded
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 2
    Fault Frequency: 1
    Time Indication: 0
    01304 - Radio
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 210
    Time Indication: 0
    01300 - Control Module for Navigation with CD-Rom (J401)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 210
    Time Indication: 0
    Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
    Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
    Component: SG EXT.PLAYER H13 0240
    Revision: A1001003 Serial number: 7662106636
    Coding: 010000
    Shop #: WSC 00788 648 00255
    VCID: 295945AA40DDE15056B
    1 Fault Found:
    01304 - Radio
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 210
    Mileage: 4110 km
    Time Indication: 0
    Date: 2008.14.07
    Time: 12:16:53
    Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
    Part No SW: 1T0 035 680 H HW: 1T0 035 680 H
    Component: RNS-MID H64 4020
    Revision: AB001001 Serial number: ______________
    Coding: 00010440040000910000
    Shop #: WSC 12345 123 12345
    ASAM Dataset: ------------------------- ------
    VCID: 3365A7C29211AB80EC7
    1 Fault Found:
    02873 - Control Module for Back-Up Camera (J772)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 2
    Reset counter: 210
    Mileage: 4104 km
    Time Indication: 0
    Address 56: Radio (J0506) Labels: 1T0-035-680.clb
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 2
    Reset counter: 210
    Mileage: 4104 km
    Time Indication: 0
    Address 77: Telephone (J412) Labels: 7P6-035-730.clb
    Part No SW: 5K0 035 730 F HW: 5K0 035 730 F
    Component: TELEFON H09 2902
    Revision: 1B001001 Serial number: 00007661899331
    Coding: 0A00000000000210
    ASAM Dataset: EV_UHVNA A01719
    ROD: EV_UHVNA_VW25.rod
    VCID: 285F40AE53D7D858495
    3 Faults Found:
    9457427 - Negative output audio channel for speech/telephone
    B104F 13 [008] - Open Circuit
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 210
    Mileage: 4110 km
    Date: 2008.14.07
    Time: 16:46:51
    9457171 - Positive output audio channel for speech/telephone
    B104E 13 [008] - Open Circuit
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 210
    Mileage: 4110 km
    Date: 2008.14.07
    Time: 16:46:51
    0022 - Radio
    U1066 00 [008] - No Communication
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 210
    Mileage: 4110 km
    Date: 2008.14.07
    Time: 12:16:51
    End ---------------------------------------------------------------------
    MY16 Candy white Octavia VRS Wagon, sunroof, 19" black pack, tech pack, comfort pack, auto tail gate
    MY12.5 Polo 6R GTI
    Aug 2011
    They're probably red because you had the Radio unplugged while the car was on, so the modules couldn't talk to it for a while.
    As with the camera did you tick Byte 3, Bit 6 in the Radio/Nav seciton?
    May 2012
    Yea ticket bit 6. I reset the faults and ran another log but still red. The one that worries me is the can gateway saying it incorrectly coded. How did that happen.
    Also the back up lamp open circuit. Has anyone else with a RVC seem this fault.
    And it seems to be lookin for the reverse camera module. But ther isn't one for this.
    MY12.5 Polo 6R GTI
    Aug 2011
    Quote Originally Posted by lunchboxGTI View Post
    Well the fault codes all seem to indicate a bad connection with the Radio, perhaps the quadlock isn't in too well it's easy to half lock it at times.
    As for the RVC someone in the Audio and elec section had a very similar problem. It might have some tips in there.
    Black RVC Screen
    Jun 2008
    Ringwood, Victoria
    Stoopid question here but are you 100% sure you have wired it correctly i.e my situation trying and trying to work out why my reverse screen stayed black, only to find my camera's video out wasn't actually plugged in.....
    Apr 2010
    Back up light error makes me think the wiring is incorrect. Also to have all of those other errors makes me think there is a problem with the CAN Gateway - I had similar faults when mine was disconnected. But then I didn't think the Polo had a Gateway module as such...
    Aug 2011
    I think the CAN errors seem to be related to the Reversing Camera some how being added to the installation list. Just untick it and the CAN errors will go.
    May 2012
    I have got rid off all the errors. And even though the camera is still blank the have not returned.
    I had a read of the other thread on black screen and I'm going to crack out my RCD 510 and see if it work with that.
    The other thing that gave them grief was having bit 6 ticked in nav and radio coding And having to untick it in radio. Mine will auto tick both if I do it in nav. I untick it in radio but when I go back in its ticked? Even after a reset.z
    MY12.5 Polo 6R GTI
    May 2012
    So it works with my RCD510. Which means wiring and camera are good. Now I'll have to reed trough about ten other threads to see how the fixed it with the RNS.
    MY12.5 Polo 6R GTI
    Aug 2011
    Nav and Radio are the same unit with the same coding, they need to be ticked on both (but you only do it once on either Radio or Nav)
