Results 1 to 3 of 3
Thread: Wheel width confusion
    Feb 2015
    Queensland Australia
    Evening all,
    I have tried to use the search function to find answers but none so far so sorry if this has already been asked!
    I have a 6r Polo GTI and looking at some Enkei RPF1's in the size of 17 x 8. My question is can you go for a width of "8" on the GTI polo or will you have clearance issues? The person I spoke too over the phone at the wheel distributor said you can go 8 on a golf however was unsure about clearance on a Polo.
    Cheers, Sean
    Dec 2012
    Sutherland Shire, Sydney
    It's not just a width issue - you need to be aware of the offset (ET)
    Measure the distance between your current rim and the shock - and find the current offset
    Then use a wheel (offset) calculator to work out what will and won't fit
    Apr 2013
    Put 17x8 et.35 Enkei RPF1's on my Fabia recently. Should fit ok with the 215/40r17 tyres. But do as Martin said first before buying.
    2012 Fabia II VRS Estate - APR stage 2 tune, Custom 2.5" turbo back full stainless exhaust with ceramic coated dump pipe, Harding Performance Cold air intake, Wagner Tuning Competition Intercooler, GFB DV+ diverter valve, Braille B2317RP battery, Eibach pro kit springs, Bilstein B8 shocks, Harding Performance F+R ARB, Super Pro bushes, Porsche 986 Boxster S front brake calipers, 330x28mm front rotors, Ferodo DS2500 front pads and Remsa rear pads, Enkei RPF1 17x8 et.35 with 235/40R17 Yokohama AD08R tyres, Maxton front splitter and Superskoda fender flares.
