Just got back from a wheel alignment as I found that the drivers side tyres inner edge was down to the canvas (I know.. I should monitor them more).. Anyway the results are :
Tow Before LH/RH
Tow After LH/RH
-2.6mm +0.9mm
+0.4mm +0.3mm
Camber Before LH/RH
Camber After LH/RH
-0.41deg -1.13deg
-0.43deg -1.13deg
As we all know the camber is not adjustable but that would at least explain the wear given the factory parameters are +-0.30.
I have not had an accident, ran up any gutters at speed aside from the odd unforeseen pothole.
So my question is, while there is no official camber adjustment mechanism aside from moving the subframe (which I don't want to do), is there ANY adjustment at all that people have been able to find? Any of the bolts give a little or similar? Could the top strug mount have moved / started to collapse which could cause this?
Any suggestions on what to try to resolve this?
My Car(s): 2011 6R TSI Comfortline (Pepper Silver),
If you're in need of any 6n1 parts, odds are that I am going to have them (dismantling 2 at the moment)
