Results 1 to 5 of 5
Thread: Wheel spin with Potenzas
    Oct 2010
    northern beaches nsw
    Morning all. Once again asking about a solution to wheelspin on my 1.8T 6C.
    I run the Potenza at around 37PSI front with decent tread but wheelspin seems excessive.
    Is there a grippier tyre out there, and also a tune that flattens that early torque curve you get with this model?
    Thanks
    MK4 GTI Revo Stage 1 / BFI Dogbone Mounts / 710N DV
    Jun 2011
    RE003 potenza?
    If you are talking about the RE003 Potenzas, then there are most definitely better/grippier tyres available but you will have to spend more. The RE003's are pretty affordable, be prepared to pay approx $100 more per tyre to step up to something better.
    RE003’s are good when new but as they wear the grip levels tend to drop off to the point that you want to change the tyres before they are due.
    Apr 2014
    The Monash Freeway
    My mileage varied, so to speak. The 1.8 is very torquey in first so you had to moderate your throttle use. Most tunes will flatten it out a bit. Give Alex from Underground Performance in Vic a call if you need a good tune.
    Ben
    Now: ‘19 VW Golf R, ‘15 Polo GTI
    Before: ‘06 RenaultSport Megane 225 Cup, ‘14 VW Polo GTI, ‘12 VW Golf GTI, ‘06 VW Golf GTI, ‘05 VW Golf Sportline, ‘01 Holden Astra SRi, ‘00 Nissan Pulsar SSS, ‘99 Holden Astra CD, ‘98 Nissan Pulsar SLX, ‘91 Nissan Pulsar GL with Q engine swap, ‘80 Subaru Leone
    Ben
    2015 Polo GTI & 2019 Golf R
