Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 50
Thread: Wheel and lowering advice :)
  1. #31
    Jul 2012
    Melbourne, VIC Northern Suburbs
    Quote Originally Posted by bigfoot View Post
    like this wee laddie?
    I'm probably of the same school of thought as gavs. If I had a set amount of money to spend, first I would make my car faster for mountain-type roads (more power, less weight, better grip) without sacrificing too much comfort and practicality.
    I tend to favour a car that looks very stock because I prefer to blend in rather than stand out and I doubt that I would spend money on anything that didn't make the car do something better or feel better doing it. Purely cosmetic mods would be a very hard sell and any mods that actually degraded the performance of the vehicle would not even be considered.
    Having said that, I do love non-stock mods that you might expect to see on a factory-special or motorsports/tuning arm version of an already decent car. To me, the car above is a stunning example! Big wheels that fill the guards and look like they were made for it, aggressive stance without looking like something has failed or collapsed and an overall stealthy look that oozes controlled aggression.
    But! ...as much as some of the more outlandish and purely cosmetic mods get me muttering under my breath like an old Grandpa, I genuinely appreciate the diversity, individuality and creativity that car enthusiasts display. Some make me shake my head in disbelief (seriously, what is the deal with tyre stretch??), some make me LOL and some make me go "WOW!" (that matte grey vinyl-wrapped jobbie). I wouldn't dream of doing even 1% of what I see to my own car and if you did it for me I'd have you charged with vandalism, but the enthusiasm is genuinely infectious and makes me constantly question my mental/emotional boundaries which is awesome.
    So keep the awesomeness and ridiculousness coming!!!
    Polo GTI MY13 (CTHE) | 5D | CW | Sunroof | DL Tint | VW Handy Adapter for iPhone 4/4S | DHL disabled
    VCDS tweaks: XDL - Strong | Brake Assist - Hard | Auto Lock Doors/Hatch - On | Two Stage Unlock - On | Audible Locking - On | Lane Change Function - 4 flashes
  2. #32
    Jun 2008
    Ringwood, Victoria
    Quote Originally Posted by kam View Post
    can anyone confirm if when putting lowered springs into the car, the hub nuts need to be replaced as well ?
    im getting some people saying i should, and others saying they didnt
    Hub nuts?! How are you replacing the springs? Are you popping the drive shafts out? There is a way that used to work very well on the mk4 golf that didn't require removing the hubs but it could be hit and miss if it would be easy to remove the struts....
  3. #33
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by gavs View Post
    I'm not having a go
    Yes you are but there's nothing wrong with what you are trying to point out
    This was my last tilt at this particular windmill (for now...) Does your VAG handle? It depends...
    Resident grumpy old fart
  4. #34
    Jun 2008
    Ringwood, Victoria
    Quote Originally Posted by kaanage View Post
    Hmmm, it could be construed as that but I was pointing out that because of the geometry of this platform that when lowering is done for "performance" regards, it is to detrimentally effect perfomance, not increase it. That's all.
    i apologise for any offense, it was meant as a factual comment, not an offensive one.
    Final point from me on the subject (I can hear the sighs of relief!)
    Those of you considering lowering your vehicle for "handling" reasons, PLEASE PLEASE PLEASE read what Greg (kaanage) has written. There is A LOT of information in there explaining in technical detail as to why I harp on about this point.
  5. #35
    It always amazes me that people buy a performance model of a vehicle and render it completely useless of its intended purpose.... I'm not pointing fingers here I just, well, I don't get it. Buy the model that can get you around and dress it up, why buy a car with basically double the performance of the next lowest model and then hamstring the hell out of it. It's like pulling the turbo off to "neaten the engine bay".
    Anyhow, just make sure that as you go lower you get rear wheel centering adapters because the 6R geometry will move the rear wheel forward in the wheel arch as you lower it and it looks rubbish. You can buy the mk4 golf ones from ECS Tuning and I'm pretty sure they will fit up
    Rear wheel centering adaptors? Is the 6r honestly that bad after you lower it?? Anyone else on here had that problem with their polo?
  6. #36
    May 2011
    Albury, NSW
    Quote Originally Posted by discodave83 View Post
    I doubt it - the 6R is no different to the 9N3 in it's suspension set up (I'm assuming) - none of us guys have had to do it. You can tell it goes off centre when you're at max lows and then have 50-100kg in the boot - but it doesn't look bad.
    I'd rather wheels off centre by a few mm than the wheel gap you 6R boys are running
    2019 132TSI Tiguan
    2011 Audi S4 Wagon
    1988 MK1 Caddy
    2006 Polo GTI
  7. #37
    Jul 2011
    ^^^^^^ what he said
    Quote Originally Posted by nightphotographer View Post
    hahaha well put bud, hard to look at an amarok spec polo...
  8. #38
    Mar 2011
    Yes it is that bad but I probably I hate it moreso because I'm a symmetrical right brained graphic artist lol
  9. #39
    Jun 2008
    Ringwood, Victoria
    Yes, it really is that bad. Not so much with 18" wheels but the wheel arch is too big for 17" wheels to go that low.
  10. #40
    Eltham, Victoria
    For those playing at home: Pick your camp (AFAIC there are 4).
    1) Leave it stock height (change your wheels if you so wish).
    2) Lower it for lowering the body's sake (through the use of springs, coilovers, smaller wheels, smaller tyres). If this is your goal, you will get that rear wheel tilt forward (beam rear end will result in this, only drop plates will remedy it) which is only exaggerated when using small/smaller wheels/tyres.
    3) Lower to improve arch gap. This is a popular one for those who want to fit aftermarket wheels (often a bigger diameter with smaller profile tyres). This school of thought pays little attention to the actual clearance of the car and more to the arch gap. Probably the most visually appealing to the majority (but we can't please everyone, can we?)
    4) Address your suspension (amongst other things) for handling sake (Kaanage, Buller_Scott and Gavs have all made valid and educated comments on how to best go about this so don't expect a set of springs, let alone coilovers, to dramatically improve the cars handling prowess).
    Feel free to chime in if I've missed anything, guys. Just trying to provide some material for people to absorb.
