Page 22 of 26 FirstFirst ... 122021222324 ... LastLast
Results 211 to 220 of 256
Thread: Whats with the removable bluetooth screen thingie?
  1. #211
    Nov 2012
    Quote Originally Posted by anglo_dude View Post
    I think this is a feature of the BT Audio implemented in the VWs. You have to start the music playing from the phone before it will go through to the head unit. Kinda defeats the purpose of BT audio in my opinion and mean that you have to keep pressing buttons on the phone to listen to music, which is illegal now...
    I've just gone out and bought an SD card and put my music on there and am using it in the head unit (RCD-510 here, so it may be different functionality).
    Cheers,
    Anglo
    Makes no difference, no audio comes out.
    iPhone 5 connected to VW PHONE, and when playing music, speaker output is even selected as VW PHONE.
    I'm thinking either:
    1) The bluetooth unit needs to be upgraded... not sure what is installed on the 77TSI, may be different from GTI
    2) The system needs to be upgraded from RCD310 to RCD510...
    3) Some type of vagcom work needs to be done
    4) Some or all of the above.
    The problem with this thread is that it refers to RCD510 and/or GTI models with MDF, but not RCD310 / non GTI models without MDF.
    Any clues? I would hate to upgrade the wrong thing...
  2. #212
    Apr 2011
    Sunshine Coast, QLD
    Quote Originally Posted by cappuccino View Post
    This happened to me with my Android phone... until I turned the Media Volume up on the phone...
    2011 Polo GTI | Black | 5 doors | Comfort pack | Audio pack | 9w7 Bluetooth | Xenons - a Return to VW!
    Previous ride: 2008 Mazda2 - ZOOM-ZOOM indeed!
    1st Ride: 1988 Red VW Fox Sedan!
  3. #213
    Jul 2012
    The quality will be superior to BT, good choice.
  4. #214
    Nov 2012
    Quote Originally Posted by RoknRob View Post
    nope, not the issue. when i switch from vw phone to touch adapter works. iphones done have media volume.
  5. #215
    Apr 2011
    Sunshine Coast, QLD
    Ok... Actually, I think on my Android, there is even a separate Bluetooth Media Volume...
    just checking... I wish it had been that simple... Good luck.
  6. #216
    Nov 2012
    i wish it was too
  7. #217
    Mar 2011
    Wollongong
    I have never managed to get bluetooth audio working on my tsi either. I have an android phone with standard touch adapter. While the phone says media is playing through bluetooth I get no sound. I just assumed that it doesnt work. Same as messages and voice dialling names. Would be very interested to hear if any non gti owners with rcd310 have got any of that working. Other than answering incoming calls I find it useless. I could be just bluetooth retarded. I only just worked out you can change display settings on the stupid screen thingie. I have 2 fixes for the audio. I copied music onto a usb stick and leave it in the glovebox mdi. I bought a retractable cable for the aux-in socket.
  8. #218
    Mar 2011
    Wollongong
    Hey, I cracked it! Perseverance paid off.
    First, on the rcd310 press menu button, press setup, press bt-audio to make sure it is ON.
    Second, on the touch adapter press more, scroll down, press settings, press audio, make sure the mobile audio option is checked.
    When all the people above said the sound quality would be crap I thought it would be OK, just not CD quality. I just found that it is grandpa's old transistor radio crap. Honestly, it is worse than my phone speaker. It is probably only useful for navigation (havent tried it)
  9. #219
    Nov 2012
    Quote Originally Posted by amazeer View Post
    umm, i think you should read the thread in full... we already know this. the phone connects via BT to the cradle and again via BT to the car, hence bad quality. hence why im trying to connect directly via BT to the car bypassing the cradle.
    this is the problem. there are various solutions in this thread, but only for the RCD510 and GTI.
  10. #220
    Nov 2012
    Ok, i've checked the bluetooth unit and I think its the latest one (9w7), doesn't say 9w7, just says:
    706 035 730 L
    SW: 3200 HW: H15
    Model: UHV
    MCD: SJA 39/12
    I think this is the 9w7 as googling around it seems to be it. Also, the 9w7 is the only one that will support audio stream and controls and appears as VW PHONE.
    I don't think the RCD310 needs to be upgraded, the 9w7 BT unit should connect up the the RCD310.
    So i'm thinking vagcom now. maybe software updated needed for iphone 5.1?
    Going to try a different phone see how that goes.
