Talking about iPhone5. I assume VWs MDI wont work with the new iPhone5.
I've already VCDS coded out the touch screen thingie and can remove it. My phone connects to the underseat bluetooth.
But does anyone know if a Bury System 8 Universal cradle
ie this one Take&Talk Universal - Universal connection set with Bluetooth interface for UNI System 8 hands-free car kits
will fit the VW base?
The VW Base is based on Bury System 9. No idea if System 9 bases are compatible with System 8 cradles.
Probably better to get this
BURY ActiveCradle Universal NEW - Active cradle for a wide range of smartphones
Also worth noting for people considering a cradle, it will actually use the external roof antenna even if you don't have rSAP - boosting your phone's reception.
A passive antenna is in the base/cradle and that connects to the roof antenna, it's one of the main differences between System 8 and System 9.
MDI still seems to have slightly better audio quality than the BT though...
That's to be expected. BT has some pretty heavy compression with it. The MDI would access the iPod interface (which means you can play around with playlists etc)
That also means you might lose some controls if you use a 30pin ipod MDI cable with the new iPhone 5's Lighting adaptor. You'd probably need to source an iPhone 5/Lightning cable from VW as the lightning-30pin adaptor apparently doesn't support this ipod connectivity (as in the ipod interface - will still play audio)
Or you can try to buy from the UK sites for about 32 quid ($4plus shipping:
https://www.systo.co.uk/uncategorise...37-2000-0.html
If you give them a call they might agree to ship to Australia for a premium?
MY13 Polo GTI, also Candy White with pleather
