Page 14 of 26 FirstFirst ... 4121314151624 ... LastLast
Results 131 to 140 of 256
Thread: Whats with the removable bluetooth screen thingie?
  1. #131
    Aug 2011
    Quote Originally Posted by ill0gitech View Post
    I've also got a MY12.5 GTI with RCD510, paired through the MFD, but as soon as I took away the touch adapter from the dock and put my own Bury cradle in, I got the touch adapter missing alert on the MFD. But then mine's not the genuine VW one, which it's been mentioned doesn't need coding
    Correct.
    Bury cradles do need coding, VW cradles don't.
    There is some new coding options for the BT in VCDS 11.11.4 too. Allows you to change how the phone book is sorted (first or last name) and some other stuff.
  2. #132
    Talking about iPhone5. I assume VWs MDI wont work with the new iPhone5.
  3. #133
    Aug 2011
    Quote Originally Posted by pologti18t View Post
    Reading the thread you started in the audio, it looks like it'll operate much like the iPhone works over A2DP with the newer Polos.
    Play/Pause/Now/Next and thats it, hopefully track info too.
    Looks BT audio and a cradle is the future for iPhone sound in the Polo
  4. #134
    Sep 2012
    I've already VCDS coded out the touch screen thingie and can remove it. My phone connects to the underseat bluetooth.
    But does anyone know if a Bury System 8 Universal cradle
    ie this one Take&Talk Universal - Universal connection set with Bluetooth interface for UNI System 8 hands-free car kits
    will fit the VW base?
  5. #135
    Aug 2011
    Quote Originally Posted by staz88 View Post
    The VW Base is based on Bury System 9. No idea if System 9 bases are compatible with System 8 cradles.
    Probably better to get this
    BURY ActiveCradle Universal NEW - Active cradle for a wide range of smartphones
  6. #136
    Sep 2012
    Quote Originally Posted by readerr0r View Post
    How did I miss that one!?
    Thanks reader.
  7. #137
    Aug 2011
    Also worth noting for people considering a cradle, it will actually use the external roof antenna even if you don't have rSAP - boosting your phone's reception.
    A passive antenna is in the base/cradle and that connects to the roof antenna, it's one of the main differences between System 8 and System 9.
    MDI still seems to have slightly better audio quality than the BT though...
  8. #138
    Jul 2012
    That's to be expected. BT has some pretty heavy compression with it. The MDI would access the iPod interface (which means you can play around with playlists etc)
    That also means you might lose some controls if you use a 30pin ipod MDI cable with the new iPhone 5's Lighting adaptor. You'd probably need to source an iPhone 5/Lightning cable from VW as the lightning-30pin adaptor apparently doesn't support this ipod connectivity (as in the ipod interface - will still play audio)
  9. #139
    Jul 2011
    Southbank Vic
    Or you can try to buy from the UK sites for about 32 quid ($4 plus shipping:
    https://www.systo.co.uk/uncategorise...37-2000-0.html
    If you give them a call they might agree to ship to Australia for a premium?
    MY13 Polo GTI, also Candy White with pleather
  10. #140
    Aug 2012
    wgong
    Quote Originally Posted by iigx View Post
    Just to let you know its now possible to order an iPhone5 Cradle from VW Germany. Not that the iPhone5 is out yet, but...
    Hi do you have a link for this???
