Where abouts in Melbourne are you?
I have a 2011 Polo GTI with sunroof and im looking to get the back part of the roof vinyl wrapped black. I also thought while they had the antenna out i could swap it for a shark fin.
My questions are, does anyone recommend a vinyl wrapper in Melbourne, also any advice on a shark fin antenna?
White Scirocco R
White MK3 Golf 2dr
White Caddy (Work Van)
South East, but happy to travel if the quality and price are good.
I can recomend CarX in Clayton. They are have done a lot of cars and there workmanship is really good and price from what I can tell is very competitive $150 from the sun roof back, $250 front to back. Choice of Hexis or 3M vinyls.
About the antenna, CarX said because it involves removing all the head liner (which requires all the side panels to come off) its a lot of effort for nothing, as they can squeeze the wrap under the antenna as there is a small rubber seal which is enough to keep the vinyl down.
You can then get a small stubby antenna from 'DUB Addiction along the princess hwy.
Exotic Graphics in Carrum downs.
White Scirocco R
White MK3 Golf 2dr
If you are after a proper shark antenna this is the one VW genuine SHARK FIN GPS Antenna 3C0 035 507 P Phantom Black but it's going to cost you a bit to get it fitted, but like nomadx38 said the small stuby one could just do it for you
(for the wrapping this could help just a bit http://www.tintacar.com.au/car-wrapping)
If you live near ringwood id be happy to fit the arial for you there easy and dont need to remove headliner to access the bolt under the base of the arial
Thanks for the offer Jordan. How do you get to the bolt without removing the head liner? Also do you know of a shark fin replacement? Sloau, i think that antenna is GPS only, not AM/FM
