Results 1 to 10 of 12
Thread: VW Polo GTI Shark fin antenna & Vinyl wrap roof advice
    Jan 2014
    I have a 2011 Polo GTI with sunroof and im looking to get the back part of the roof vinyl wrapped black. I also thought while they had the antenna out i could swap it for a shark fin.
    My questions are, does anyone recommend a vinyl wrapper in Melbourne, also any advice on a shark fin antenna?
    Jun 2008
    melbourne
    Where abouts in Melbourne are you?
    White Scirocco R
    White MK3 Golf 2dr
    White Caddy (Work Van)
    Jan 2014
    South East, but happy to travel if the quality and price are good.
    Jul 2011
    I can recomend CarX in Clayton. They are have done a lot of cars and there workmanship is really good and price from what I can tell is very competitive $150 from the sun roof back, $250 front to back. Choice of Hexis or 3M vinyls.
    About the antenna, CarX said because it involves removing all the head liner (which requires all the side panels to come off) its a lot of effort for nothing, as they can squeeze the wrap under the antenna as there is a small rubber seal which is enough to keep the vinyl down.
    You can then get a small stubby antenna from 'DUB Addiction along the princess hwy.
    Jun 2008
    melbourne
    Exotic Graphics in Carrum downs.
    White Scirocco R
    White MK3 Golf 2dr
    Jan 2014
    Queensland
    If you are after a proper shark antenna this is the one VW genuine SHARK FIN GPS Antenna 3C0 035 507 P Phantom Black but it's going to cost you a bit to get it fitted, but like nomadx38 said the small stuby one could just do it for you
    (for the wrapping this could help just a bit http://www.tintacar.com.au/car-wrapping)
    If you live near ringwood id be happy to fit the arial for you there easy and dont need to remove headliner to access the bolt under the base of the arial
    Jan 2014
    Thanks for the offer Jordan. How do you get to the bolt without removing the head liner? Also do you know of a shark fin replacement? Sloau, i think that antenna is GPS only, not AM/FM
    Jan 2014
    Queensland
    Quote Originally Posted by Freerange View Post
    I checked with Martin at JKU it is GPS and also AM/FM at least that is what he said
    Sep 2014
    Quote Originally Posted by SloAu View Post
    I installed one and the connectors don't match up for the AM/FM antenna. Even if you pop off the plastic connector the AM band doesn't work, FM is just fine.
    So I have a gsm connection and satellite connection but no radio antenna. Unless someone can help out?
