I have no idea what quality differences may exist between a Chinese sourced DSG v a German made one (although I might be able to guess), but I'm not sure what an Australian recall would do - given the number of multiple failures it just seems to be a fragile box.
Same applies to the 118tsi engines - great idea, but again multiple failures in some cases indicating design issues, as VW don't seem to have answers on fixing it besides replacement.
So the gamble goes on..
Write to Matt at The Age and let him know your story. I've just emailed him.
MY18 GOLF 110TSI I HIGHLINE I Indium I Panoramic Sunroof I DAP I IP
MY18 TIGUAN 162TSI I R-LINE I Ruby I DAP I IP
If VW Australia recalls them, what are they going to replace them with?
If the Chinese DSGs were locally built they may have had a production fault leading to one specific issue. There seem to be a lot of different quirks and problems in the German built DSGs, it does appear to be like they say that no two are the same.
I'm on my second DSG car in a Polo GTI after having a Mk5 2.0 TDI, it worked fine up to when I sold it at 170,000kms.
If I wanted to sit there and listen and get paranoid about every little thing I read about online though, I could. But in reality it performed flawlessly.
Resident grumpy old fart
Polo GTI - 5 door - Candy White, Xenons, Comfort Package, Audio Upgrade, Bluetooth, Parking Sensors and Tint
Karl Gehling, if by chance you are smart enough to actually look upon this forum of the biggest support community for your product in the country, may I suggest this.
Make sure that what you have said is 100% accurate because as you may know, there is a product called VCDS on the market that many of own. Part of that system has a function that can tell you the build plant code for specific components in said vehicle. If by chance, a member of the community has found a list of the build plant designations from across the globe and it shows that a single australian delivered vehicle with a DQ200 gearbox has a DSG not out of Germany, things might just turn rather pear shaped......
