Results 1 to 7 of 7
Thread: Upgrading My RCD310
Eliza Upgrading My RCD310 18-04-2015, 01:08 PM
vdubmotorworx Hi mate. Can pick you up a... 18-04-2015, 03:22 PM
Eliza Do you know if the unit will... 18-04-2015, 03:53 PM
vdubmotorworx Yes it will mate 18-04-2015, 06:42 PM
simonD40 I have a RCD510 and USB cable... 18-04-2015, 07:24 PM
simonD40 The unit is 8 weeks old ... 18-04-2015, 07:24 PM
Eliza I sent you a Private message... 18-04-2015, 08:46 PM
    Mar 2013
    Brisbane QLD
    Hi mate. Can pick you up a RCD510 for around $250-300. It will be plug and play so easy install. BT kit would be good if you got the 9w7 as it displays on the RCD screen. Also if you payed for the higher price RCD510 it will have a camera socket so later down the line you could install a reverse camera flip badge
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Apr 2015
    Do you know if the unit will respond through the controls on the steering wheel also?
    Thanks for the reply!
