hello everybody!
Reading here, I discovered it's possibile to convert a dealer PDC (Park Distance Control) to an OPS (Optical Parking System).
In other words you can, apart hearing the beep, visualize on the RCD510 display the rear of the car while parking it in reverse.
Point is, the link I put is valid for a Golf, but can ot be fiitted on the new Polo (better if GTI as mine)?
Then I als see this part: 3C8919475, which is Control Unit from a Passat. Instead I'd like to put a 5K0919475E which is for Golf and able to support, in case I want to fit in a future, front parking sensor!
What it's not clear for me, can I still use the same cable that connects the Control Unit to the Canbus checking the pins or do I have to use the one in the link (part n. 000979009)
Let me know!
Ben
