Results 1 to 10 of 14
Thread: Underseat drawers
    May 2012
    WA
    Underseat drawers
    Hi Guys,
    I am wondering if it is possible to retrofit underseat drawers that were originally available in the polo. I found this but I think it is for the golf...
    VW OEM MK5 / MK6 seat drawer kits
    PS. Forgive me if this has been discussed before. I tried doing a forum search but could only find reference to Tig and Golf.
    Jun 2008
    Ringwood, Victoria
    Different seats, different draws. Yes, it's possible but you need them out of a Polo GTI.
    May 2012
    WA
    Quote Originally Posted by gavs View Post
    Hmm I wonder how many GTIs there are at the wreckers....
    Jun 2008
    Ringwood, Victoria
    With just over 600 in the country, not many. I have only seen one wreck go through the auctions.
    Oct 2010
    Melbourne, VIC
    9N3 Pacific models have them too
    Resident grumpy old fart
    Sep 2010
    These are the parts that you need:
    6Q08825999B9: Frame
    6R0882601C82V: Drawer
    6Q0881203: Glide Piece, S
    N90918701: Socket HD Bolt
    I investigated doing it, the parts totalled about $250 I think; but the labour cost was through the roof. If you go ahead some feedback on how easy the install was would be greatly appreciated.
    P.S. The first 100 6R Polo's in the country had these installed as standard, so they willl fit all Polo's not just the GTI's.
    6R Polo TDI; DSG
    May 2012
    WA
    Thanks for the information. Did you source the prices from a dealer?
    If its only bolts and screws I would be willing to give it a go
    Jun 2008
    Ringwood, Victoria
    You also need an ( for lack of a better term ) airbag signal interrupter thingy for when you disconnect the airbags in the seat because you will need to remove the seat to do it.
    Oct 2010
    Melbourne, VIC
    You may be able to get away without that.
    When I installed the drawers in our Golf, there was enough room to just unbolt the seats and lean them backwards against the rear seat for the installation to be performed (needed to tilt the front seat all the way forward first so it could lean back far enough) without undoing the seat airbag wiring.
    Sep 2010
    FlyTSI, yes the quotes were from the dealership.
    I am not one for being the first to try things; but if your happy to give it a go and post the findings I'd be the first to copy.
    Good luck!
    6R Polo TDI; DSG
