Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Underseat drawers
FlyTSI Underseat drawers 09-06-2012, 01:34 PM
gavs Different seats, different... 09-06-2012, 05:10 PM
FlyTSI Hmm I wonder how many GTIs... 09-06-2012, 06:53 PM
gavs With just over 600 in the... 09-06-2012, 09:00 PM
kaanage 9N3 Pacific models have them... 09-06-2012, 10:02 PM
William_Foster These are the parts that you... 11-06-2012, 07:15 PM
FlyTSI Thanks for the information.... 11-06-2012, 09:21 PM
William_Foster FlyTSI, yes the quotes were... 12-06-2012, 06:56 PM
Billecartz Our Polo has these:banana: 12-06-2012, 07:25 PM
gavs You also need an ( for lack... 12-06-2012, 10:19 AM
kaanage You may be able to get away... 12-06-2012, 01:46 PM
    Jun 2008
    Ringwood, Victoria
    You also need an ( for lack of a better term ) airbag signal interrupter thingy for when you disconnect the airbags in the seat because you will need to remove the seat to do it.
    Oct 2010
    Melbourne, VIC
    You may be able to get away without that.
    When I installed the drawers in our Golf, there was enough room to just unbolt the seats and lean them backwards against the rear seat for the installation to be performed (needed to tilt the front seat all the way forward first so it could lean back far enough) without undoing the seat airbag wiring.
    Resident grumpy old fart
