Results 1 to 10 of 23
Thread: GUIDE: Fix those squeaky door seals!
    Do your door seals squeak as you drive over uneven bits of road? Mine did, but I fixed them.
    Here's how:
    Firstly, go to Bunnings (or rummage around your shed) and get yourself about 5 metres of ~6mm diameter irrigation tubing. If you have a choice, get the harder stuff, not the soft rubbery stuff.
    Next, get one end of it and feed it down your top door seal, between the two strips of felt:
    Run it all the way to the end of the seal, then cut it to length:
    Make sure it all sits snugly, then close the door. You should notice that the door closes more tightly.
    Repeat this process for all doors (not the boot).
    People in other forums around Australia and the U.S have applied this fix and have noticed an improvement. I have applied this to my Megane (the Polo's seals weren't noisy) and it has made an improvement.
    Hopefully this guide can help others too! (and maybe be stickied?)
    Alex.
    Alex Aescht
    MY13 Dark Silver VW up! 5-door 55MPI manual — Comfort Style Pack, Comfort Drive Pack, Maps + More, Panoramic Sunroof
    MY11 Pepper Grey VW Polo Comfortline 66TDI manual ― Comfort Pack, Audio Pack.
    Jul 2011
    To add to alexaescht's post:
    Did this a few months ago and its worked well enough but the creaks are coming back. So 6mm may be the size to go, although the 4mm was a nice fit.
    I got the 4mm irrigation tubing. Cost me around $5 for 25m.
    And it was as simple as feeding the tubing through the gap between the felt and rubber.
    It's pretty much fixed the 95% of the creaking. A few here and there, but definitely not as noticable and prominent as before.
    Just felt like sharing in case anyone didn't know there was a fix out there for us Polo owners
    Polo 6R GTI - Candy White | MY12.5 | 5 dr | Weitec Hicon GT | OZ Ultraleggera | SPOC - 1st Four
    Quote Originally Posted by alexaescht View Post
    Alex.
    The Golf guys have been running this as well, particularly after inadvertently getting wax near the seals. I tried the rubbing alcohol technique which made a minor improvement, then went for the hose and bingo - solved in all but 'extreme' situations eg. driveways entries that 'twist' the car.
    Over time the tubing may start to give a little, so it's a case of either replacing it, or some have sliced it open and slide a second piece through (this may become too tight on certain doors). Regardless, given the price of the tubing it's not a big deal.
    It's a worry that garden tube fixes what VW couldn't be bothered dealing with in their seal material/design.
    Aug 2012
    Awesome Guide! My front-left passenger door is so noisy so I'll be applying this fix soon! Cheers Alex!
    MY16 Golf GTI Performance Pack
    Previously: MY12 Polo 77TSI
    In The Family: MY15 Golf 103TSI Highline & MY15 Audi RS3
    Mar 2010
    08 Golf GTI - SOLD
    Pacific Paradise QLD
    Has anyone given any thought to just adjusting the striker on the pillars to tighten up the door a bit.
    Jun 2008
    Emerald, Vic
    i find that gumipfledge stuff is good also for short term reduction of the noise.. BMW used to make a great one, but alas thats long since gone, i have bought a myriad of replacements lately, the sontax stuff from germany is not bad, seemed to work quite well..
    My Car(s): 2011 6R TSI Comfortline (Pepper Silver),
    If you're in need of any 6n1 parts, odds are that I am going to have them (dismantling 2 at the moment)
    May 2013
    Sunshine Coast, QLD.
    We had our doors and strikers adjusted by the dealer and it made no difference.
    On another note, I got some of the tubing today. Bunnings had basically every size EXCEPT for 6mm in the black tubing, so I ended up getting some 6mm clear tubing. Gonna have a go tomorrow!
    Quote Originally Posted by Barracuda View Post
    You're welcome
    Sent from my iPhone 4 via Tapatalk 2.
    Alex Aescht
    Jun 2008
    Ringwood, Victoria
    Quote Originally Posted by pontiff View Post
    It's the same stuff supposedly, initially it was made specifically for BMW and then Einszett started selling it themselves. It's not the same as the ok paste stuff but better than pretty much anything else.
