By the way, if you have a coloured tail light lens, you might not get what you expect if you use a coloured LED.
Basically, the reason you see a red light is because the lens absorbs all the colours except red and passes that through. If you use a red light and the characteristics of the red light does not match that of the tail light lens, you will find that the lens might absorb some of the light produced and pass only that the lens allows through. This is basically why the original bulbs are not coloured.
I went through this exercise on my last vehicle (Hiace ABV) where I fitted LED bulb replacements. The set I got had a coloured dome, and the light coming through the lens was very dull. Dremel tool and a little time saw me cut off the coloured dome and the light seen through the lens improved dramatically.
By all means, you can get the coloured LEDs, see if you can check them out before you buy. The white ones might be better.
