In the past I would be running as high as 36psi on the street. While this is great for fuel economy, it will tend to over heat the tyres to quick on the track. On the street now I use around 32psi on the front and 30psi on rear (factory recommended btw) and when on the track I use 28psi on the front and 27psi on rear. This can still change due to road temps.
While your at it why not check out the price of some federal 595RS-R's. Great street and beginners track day tyre and should be half the price of euro tyres. They do a 245/35R18 tyre.
2012 Fabia II VRS Estate - APR stage 2 tune, Custom 2.5" turbo back full stainless exhaust with ceramic coated dump pipe, Harding Performance Cold air intake, Wagner Tuning Competition Intercooler, GFB DV+ diverter valve, Braille B2317RP battery, Eibach pro kit springs, Bilstein B8 shocks, Harding Performance F+R ARB, Super Pro bushes, Porsche 986 Boxster S front brake calipers, 330x28mm front rotors, Ferodo DS2500 front pads and Remsa rear pads, Enkei RPF1 17x8 et.35 with 235/40R17 Yokohama AD08R tyres, Maxton front splitter and Superskoda fender flares.
No argument from me on any of the above!
I definitely have the largest OE combo Audi sell on the A1, so 15mm more is it. But totally with you on the difference due to tread on a new set. On the way to Melb I went under the big digital speedo check and my own digital speedo at 100 read 98 on the overhead sign, on low tread. So fresh tread with my OE tyres should have been bang on accurate and these new tyres should have me running 2-3% over displayed speed, getting closer to dead on accurate as they wear.
I hate Australia tax too, and believe me, if the dollar hadn't tanked so hard I'd be buying from Tirerack or Performancealloys, but now the freight rubs out the advantage.
2014 Audi A1 Sportback Sport
APR Stage 2 - HP DQ200 DSG tune - Quaife DQ200 LSD - LuK RepSet 2CT clutch - VWR CAI - Wagner Competition FMIC - Milltek DP & resonated cat-back - HP F&R sways - Bilstein B14 coilovers - Tarox Sport Compact brake kit - GFB DV+ - Whiteline LCA bushings w/ +caster - SuperPro race dog bone insert - Fondmetal 9RR matt black 18x8" wheels - Michelin PSS 245/35R18 - gloss black RS honeycomb grille - OEM clear lensed LED tail lights
