Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: TMC
  1. #21
    Aug 2016
    Campbelltown
    Ah ok in that case it's likely the same.
    I have NO IDEA however if what I have is safe to load on your unit.
    It has been modified.
    You can use it at your own risk but I have no idea if it will brick it.
    6xx is not compatible.
    I guess if the my unit gets bricked I can pay VW to fix it.
    Modified in which way?
  2. #22
    Quote Originally Posted by ibiglari View Post
    Update.
    I enabled WiFi on Discover Media Now I have to find a way to sign up for Car Net.
    Regarding TMC, I'm still browsing other forums. 1024 appears to be the correct decryption key, but I still see TMC with a diagonal line on it when I go to the traffic page :'(
    So you have Car Net working on an Australian Spec vehicle? Do you have full functionality?
  3. #23
    Aug 2016
    Campbelltown
    Quote Originally Posted by loj94jdn View Post
    No. I have menu items, but can not register for Car Net because it asks for a PIN code which I don't have
    MY16 81TSI Polo - DSG - Driver Assistant Package
  4. #24
    Aug 2016
    Campbelltown
    OK another update. Only when TMC channel is set to 1024, the unit saves TMC Data packets to the log file (which I enabled in GEM). The TMC packets are valid. I wrote a short script to decode them, and below is a sample:
    RDS message (frame 986)
    Programme Identification: 0010101000011010 (2a1a)
    Group type code/version: 1000/0 (8A - TMC)
    Traffic Program: 1
    Programme Type: 01010 (10 - Pop Music)
    Decoded 8A group:
    Bit X4: 0 (User message)
    Bit X3: 1 (Single-group message)
    Duration and Persistence: 000 (no explicit duration given)
    Diversion advice: 0
    Direction: 0 (+)
    Extent: 111 (7)
    Event: 00001000110 (70 - traffic congestion, average speed of km/h)
    Decoded Location:
    <no location table specified>
    Raw dump | Data Checkword Hex
    Block 1: | 0010101000011010 2a1a
    Block 2: | 1000010101001000 8548
    Block 3: | 0011100001000110 3846
    Block 4: | 0111101101001100 7b4c
    RDS message (frame 1077)
    Traffic Program: 1
    Decoded 8A group:
    Bit X3: 0 (Multi-group message - first group)
    Continuity Index: 011
    Direction: 1 (-)
    Extent: 001 (1)
    Event: 00111110100 (500 - (Q) lane(s) closed)
    Decoded Location:
    Block 2: | 1000010101000011 8543
    Block 3: | 1100100111110100 c9f4
    Block 4: | 0110000111011000 61d8
    RDS message (frame 1267)
    Traffic Program: 1
    Decoded 8A group:
    Diversion advice: 0
    Direction: 0 (+)
    Extent: 010 (2)
    Event: 01010111101 (701 - (Q sets of) roadworks)
    Decoded Location:
    Block 3: | 0001001010111101 12bd
    Block 4: | 0111111110010100 7f94
    I guess the issue is with location database not being present on my head unit. Can anyone confirm?
  5. #25
    Interesting find. Need to get a similar log from a working unit to compare.
  6. #26
    Aug 2016
    Campbelltown
    That's the hard part
  7. #27
    Next time I see one I'll try and grab a log.
  8. #28
    Any luck on this yet?
  9. #29
    No haven't seen one for a while I've been busy on my car.
