Results 1 to 7 of 7
Thread: Tighten Rear Sway Bar?
    Apr 2012
    Previously (while ago) I was in the talks of getting a front sway bar to even out the body roll but after taking my car in for it's service a few months back I asked the guys to recheck the sway bar to see if everything was ok. Well turned out that the figure 8 rings that hold the bar onto the wheels were put in reversed which mean't the tension wasn't at it's stiffest according to him. He swapped them over and re-tighten the bar and oh my god was it better. I was actually happy with the results.
    Now i'm starting to fear that it's going back to normal and the things are loosening up again. My question is should you get the sway bar re-tighten every 6 months or so, or is there better bushes you can get or something that keeps the bar stable? I've gone under and done a manual re-tighten but that didn't do anything and I wasn't sure I was going to damage anything so just wanted to ask what does everyone else do?
    I've got a Whiteline Sway-bar btw.
    GOLF GTI MY11 ADIDAS Candy White, Sunroof
    GOLF GTI 40th ED, White with Sunroof
    Aug 2006
    Far North Qld
    I'm also interested, as I also have the whiteline s/b.
    Bassik, what setting do you have it on?
    I have mine just stronger than middle, but this bar has a lot of adjustments (7?)
    will likely get it adjusted a bit firmer at next service, but would be good to know what to tell service techs about what to check...
    cheers
    okief
    White 3-dr Polo GTI
    Tiguan 189TSI
    Apr 2012
    Really 7 I've got mine on the stiffest setting. Thought there was only 3 levels.
    It tends to weaken over the course of 3-6 weeks I've noticed so would like to know how and what to do to maintain it?
    Apr 2012
    Bridgeman Downs ,Brisbane
    mayby your just getting used to it?
    ive got the whiteline rear swaybar aswell and i dont think ive experienced anything like this, will keep an eye out for it now though
    Apr 2012
    Quote Originally Posted by VWplo View Post
    Oh no I definitely noticed a difference after a few months it was amazingly stiffer. A mate from work could even tell after he drove it once.
    Apr 2012
    hhmmmm might get pedders to check mine when i go there i a couple of weeks
    Jan 2009
    blankedy
    Nothing should be getting loose, have a look.
